Question about Kitchen Ranges
I'm getting gas to the piolit but not the burner what is causeing that ?
  • 53 Answers
Usually a build-up of white stuff at the gas outlet near the pilot. Try cleaning it with a small brush. If this doesn't work, confirm that there is an increase in gas flow when you turn up the range control. If not, it could be a bad control valve.
Posted on Apr 12, 2014
Intertherm fireplace model bdm35
Check the thermocouple, it generates the electrical power from the flame of the pilot to open the gas valve.
Dec 10, 2013 | Heating & Cooling
The pilot light won't stay lit when you turn it from pilot to a temperature setting
some times there is a glitch in knob.try holding flame at piolit while turning knob.be careful.do not bring flame later.you might be able to raise flame size .what happens when main valve comes on there is a slight drop in pressure look on gas valve for adjusting screw, might be under a cap . if none of this helps the orifice might be too small you have to take piolit assembly apart to get to it.
Jan 01, 2011 | Heating & Cooling
Pilot will light and stay lit for 1 to 2 mins. Logs lit once but only for about 30 secs. There is NO gas flow after the fire goes out. If you wait a few minutes there is enough gas to repeat this same...
this is closely guarded secret. get a can of air for dusting computers and lightly blow dust out of piolit assembly.I've made allot of money doing this.merry xmass.if this doesn't work then you probbaly need a new part.or if piolit is too small it might need cleaning.
Dec 24, 2010 | Heating & Cooling
I have a Procom MN300HPA ventless heater and the pilot will not light with well gas. Is there some type of converison necessary to get this unit to work or do I need to get a new unit. ProCom will not...
yea,they don't want any liability.a pressure conversion for most gas valves is simply changing a spring.you can get an adjustable regulator if yours doesn't come apart.sounds like you have enough pressure I'd take the piolit apart and open up the orfice hole its real tiny.also burner hole could be widened a bit.I'd never do this for a customer because of liabality,but would be safe as long safties are in place
Piolite light keeps going out after unit turns on and reaches temperature set on thermostat.
Check gas pressures standing and working make sure pilot burns correctly and thermocouple is in good order
Dec 13, 2010 | Empire DV-215 Direct Vent Natural Gas...
I have a model 110.92832100 Kenmore Elite gas dryer that has stopped drying. i found a penny welded onto the Thermal fuse, so I replaced it and while I was in there I replaced the thermostat. When the...
Since you are already this far you have some knowledge of how you dryer works. What is wrong now is the heat sensor that picks up that the pilot is on. The pilot should burn at a steady flame when you turn the dryer on to heat this in turn heats a probe next to the piolit this is a type of heat sensor. When the probe or heat sensor senses heat it tells the gas valve that its okay to turn on. Have a great day and hope this helps.
Aug 19, 2010 | Kenmore Dryers
The oven doesn't light the piolit comes on but doesn't ignite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 04, 2010 | Maytag MGS5770 Gas Kitchen Range
Light piolit
Hello dreas15
I need more information.
What's the model number.
How old is it? Today's dryers have electronic ignition.
Waiting for your response! I will respond right away!
Huuum
Sep 22, 2008 | Dryers
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
