Question about Kitchen Ranges
903057-9010 how to replace the infinite switch with the replacement kit 903057-9010
3 Suggested Answers
  • 1314 Answers
SOURCE: Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Posted on Feb 18, 2008
  • 189 Answers
SOURCE: Just replaced infinite switch part # 12002125 ...
Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430.  Let me know if this info helps- have more if needed. - Thanks- ED
Posted on Mar 06, 2010
Lost control of hob rings 3 of them go from cold to boiling, only on or off,
I would recommend replacing the infinite switch and the element you are having trouble with. If you only replace the infinite switch, damage could have been done to the element coils themselves.
Nov 28, 2015 | Kitchen Ranges
Replace infinite switch on tappan range
What is the complete model number of your unit?
Apr 05, 2013 | Tappan TEF242 Electric Kitchen Range
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
At first I thought I only had a burned out drivers' side headlight. I replaced it and it worked. But neither of the two high beam lights work. In fact, when I turn on the high beams, all the headlights...
You have a rusted out ground leads to both front lamps. It may be bad enough rusting up front that effects both fenders. Run some heavy ground wires from negative of battery to both fenders, then tie in the negative lamp leads to the fenders. Might as well make sure the ground connections to everything else are holding up as well. I've added grounds to windshield wiper motors and blower fans that quit working as well.
Aug 09, 2010 | 1987 Chevrolet Nova
Just replaced infinite switch part # 12002125 on Jenn-aire JED8430 cooktop. Now burner will only come on HIGH and does not cycle.
Mar 05, 2010 | Kitchen Ranges
Need to replace the infinite swithc
I've got the switch but i had to take off the bad one and take it to the parts store to get the replacement. Stupid me forgot to snap a photo of how the wires plug back in! Did you get your fixed and which wires are L1/L2 and which are H1/H2?
Jul 06, 2009 | Jenn-Air 47 in. Pro-Style CCGP2820P Gas...
Kenmore infinite switch will not stop clicking after lighting
A little school lesson. Infinite switches on on electric ranges and cooktops. If you have clicking is it a gas range or cooktop? I have never heard of an infinite switch clicking. If it is gas, have you recently cleaned around the knobs? If not, that paticular spark switch will need to be changed. And if they are not wired individualy, the whole harness will need to be replaced.
Jul 31, 2008 | Kitchen Ranges
Wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Mar 15, 2008 | KitchenAid KESC307 Electric Kitchen Range
Feb 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
