Question about Sport & Outdoor - Others
Need instructions on how to put together a avid tent stock#2051.
Used tent no color codes on poles having problems getting together.
jaballou
  • 63 Answers
SOURCE: I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
Posted on Dec 09, 2008
SOURCE: ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Posted on Aug 20, 2009
  • 497 Answers
SOURCE: need assembly instructions for an Avid Outdoors
AVID went out of business. I tried doing some digging to find something, but its pretty scares. Are you able to get part of it installed and then come to a roadblock? or are you looking for help to get going...These are for the most part pretty straightforward to put together.
Posted on Aug 22, 2009
SOURCE: I have a greatland tent item #15710. This is a two
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Posted on Sep 20, 2009
SOURCE: where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
Posted on Dec 13, 2009
Black hard plastic broke, its where the three poles goes in to hold the tent up. need to find this part so we can enjoy using the tent
Remington tents were a licensed product manufactured by American Camper. For more information concerning Remington tents please contact them at:
Avid Outdoors/American Camper
1-800-782-2843
Sep 02, 2013 | Camping, Backpacking & Hiking
Instruction for setup of American Camper tent 8x11
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
Disney car tent assemble
I couldn't find the instructional manual, but I did find this image from another answer on FixYa that may be helpful: http://www.fixya.com/support/t9852139-assembly_instructions_disney_princess
Most dome tents are assembled by feeding the rounded (or bendable) poles through loops on the inside of the tent cover. Small connectors and joints should be included to put the poles together into the shape below. Good Luck!
Jul 09, 2012 | Disney Cars 2 Bed Tent with Pushlight
Tesco 6 Person Vis-a-Vis Tent Instructions
Whoever they employed to write the instructions should be shot or go back to kindergarten....how difficult can it be?
Anyway, this tent is relatively easy to put up IF you know how to do it...which the instructions are painfully inadequate. It (un)helpfully uses colour coding on black and white print out and not explaining which way around the longer/shorter poles should be. Actually, once the poles are in, the instructions are ok....but it is a major point and wastes a shtload of time.
There are 2 LONG (well, slightly longer) poles, with a yellow sticker on the end (which comes off after 1 use of the tent). Start on one side of the tent with 2 poles (one longer, one shorter). Slide the long pole into the inner rib (ie towards the middle of the tent), then put in the shorter pole on the outside rib (i.e.the furthest away from the middle). You do need some grunt to force these into place, but at least they go (they won't if you put the wrong pole in the wrong slot). Then do the other side of the tent, longer first (inside), shorter second (outside). Then just pin everything else together like the instructions show.
The tent is ok, just ok, not great, not terrible, although it is pretty terrible in the wind, but what do you expect for 60 quid.
Jun 24, 2012 | Sport & Outdoor - Others
Need instructions for my Avid Screen Tent, Item # 2086
What size and kind of poles for the screen room?
May 13, 2012 | Sport & Outdoor - Others
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I purchased the toy story bed tent for my daughter and misplaced the instructions on how to put it together so if you could provide me with this I would really appreciate it
    there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
    Jan 08, 2011 | Disney Toy Story Indoor Bed Tent With Push...
    Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
    I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
    May 19, 2010 | Toys
    Need assembly instructions for an Avid Outdoors #2087 screen tent
    Avid doesn't exist any more as it was bought out. The company that might have support information and your manual is called Alliance Sports Group:
    Contact information: (website is pretty useless)
    602 Fountain Parkway
    Grand Prarie, TX 75050
    1-800-255-6061
    http://www.alliancesportsgroup.net/
    Aug 21, 2009 | Sport & Outdoor - Others
    Coleman salt lake tent 9 man no instructions please help?
    the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
    May 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
    Sport & Outdoor - Others Logo
    16 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
