It wont spin just fills with water ive tried unblocking the filter that doesnt work the belts ok what now
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Unplug the appliance, check the length of the brushes on the motor they need to be creating contact through the armature to complete the circuit. Brushes start out approx 2" long and need replacing every 3-4 years dependant on usage.
its your motor and possibly could be limescale in the pump
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
SOURCE: my beko 1613 washing machine wont drain, and how do i operate the dial
You can find the user manual at the below link, check it out and see if you are operating the machine correctly, It sounds like your pump may be blocked also.
Link:
