Question about Aiwa CDC-Z127 CD Player
My volume doesn't change
The "knob" when turned has no effect on the volume, the only way to change the volume is the power button, which doesn't turn the stereo off, it instead changes it to a different volume
  • Marvin
    Marvin May 11, 2010
    replace the deck
  • 58 Answers
MORE THE LIKELY THE SENSOR WENT OUT IN THE KNOB.
Posted on Jun 18, 2009
Can the radio volume be tighten? The volume button will not change the volume unless I turn the knob many times.
the knob may be slipping on the stud it turns for the volume. you may need a new knob.
Sep 10, 2014 | 2010 Pontiac Vibe 1.8
How do I set clock on dpx308u
See pic below for reference. Press SRC button 4x to get to standby mode. Press "Boost," for 2 secs. Use volume knob to change hour. Press volume knob when hour is reached. Turn volume knob to set minutes. Press volume to set time. All done. Press SRC button again to go back to your tuner, or CD, or whatever.
Mar 08, 2012 | Kenwood Car Audio & Video
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Sound increases as you accelerate. can you switch off?
I know what you mean. Used to be a source of irritation in this otherwise super-quiet car. It was like "hey... the music plays far too loud now please drive a little slower dad". Really irritating on the Autobahn, constantly fiddling on that volume knob.
Interestingly, the instruction manual for the business CD main unit gave no clues at all! Then I found the solution at the bimmerfest BMW forum:
1.Power down the unit (using the knob) and power back up in the radio mode
(either AM or FM).
2. Hold down the "m" button (right of the display) until your display shows
a serial # xxxxxxxxxxx.
3. Using the "+" or "-" buttons that surround the center "musical note
symbol" button to the left of your display, scroll until "GAL 3" comes up,
which is factory setting. Using the number buttons 1 thru 6 below your
display, press the number "1". Your display will now read "GAL 1 ".
4. Power down the unit again (using the knob) and when you power back up,
your new setting will be effective!
5. To confirm that the new setting is active, repeat steps 2 & 3 to check
your "GAL" setting.
6. Enjoy your HK unit's volume the way YOU want to hear it!
I assume there are slightly different versions of this in different models but it goes something like this, the keyword you are looking for in the menu system is "GAL" which is a German acronym for speed-sensitive volume control (Geschwindigkeitsabhängige Lautstärkenregelung für Radio).
May 29, 2009 | BMW 1997-2001 Bmw 5 Series Radio/stereo...
My alpine works but it puts out no sound
Hold down the (F) button for several seconds. Release button and select (General) by turning volume knob and press (enter). Now select (Power IC) by turning volume knob and press (enter). Now turn knob and select (on) then press (enter). Hold (escape) button for several seconds.
Feb 06, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Volume display seems backward
This is because the volume knob on ANY stereo is actually an attenuator.  Meaning, the stereo would play at full blast (way too loud!) if left to it's own limits of power, so your volume knob is actually "dialing down" the power, or when fully turned up, letting it all flow.
The reason that the numbers change like that is it's showing you how much attenuation is happening in decibels, or dB, so for insTance, when it's at "-30" that's a pretty decent volume, but at "-5" it's much louder and your neighbors might complain.  I think you'll notice that it can be cranked to something like "+5" which on my AVR 100 will blow the speakers.
In other words, this is normal, so relax and enjoy the music!
Dec 24, 2008 | Harman Kardon AVR 5 Receiver
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
Aiwa CDC-Z127 CD Player Logo
307 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
