Question about U-Line Wine Captain (2015WC) Wine Cooler
Door seal is not tight
Is there a way to adjust the door to create a tighter seal with the rubber gasket?
  • U-Line Master
  • 842 Answers
The only adjustment on this model is the door itself by adjusting the door hinges. Loosen the top one first and try this one first, if not working enough loosen the bottom one and this should work. Good Luck
Posted on Apr 13, 2014
Replaced freezer gaskets now not sealing well
Jay, Check to see if hinge can be adjusted so door closes tighter, may be a faulty door seal, or maybe it needs manipulated to soften, shape, stretch it to seal better. You can try the dollar bill trick between the seal and fridge to locate the problem/leaking spots. The bill should not pull out with out there being a little force, no force means seal is not proper in that area. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Check The Seal On Your Fridge And Oven
How To Test And Replace Bad Refrigerator Gasket
How to Fix Gaps in Refrigerator Door Gasket
How to Check Freezer Door Seal DoItYourself com
Aug 20, 2016 | Refrigerators
Door not creating suction when door closes
the door may need adjusting
cut an place a strip of paper between the seal and the fridge and close the door
if the paper pulls out easily then the seal is not touching fridge
The suction is created when the warm air from the room that gets into the fridge when the door is opened is cooled down and occupies less space hence the lower pressure and the vacuum forms
May 12, 2016 | Refrigerators
Leaking door
Open the door and look inside at the lower left corner where the door gasket ends. See if there is any type of obstruction or foreign object in that corner. It doesn't take much to cause a door leak. Some door latches can be adjusted tighter. Look at the top door latch system and see if has 2 screws in it. You can sometimes loosen the screws and push the latch inward slightly and re-tighten the screws. That will make the door tighter when latched. Not all dishwashers have adjustable latch systems.
Apr 04, 2015 | Dishwashers
Sebring window
Look into window guide clips. These push the glass against the rubber
Oct 28, 2013 | Cars & Trucks
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
Maytag dishwasher door leaking
go around the door a press the rubber tighter!
Sep 28, 2012 | Maytag MDBH955AWS Stainless Steel 24 in....
Replaced passat side marker light. Now it does not fit tight.
Is it the bulb that does not fit tight...or the socket is loose in the bezel? You can carefully (with needle nose pliers and/or small screwdriver) bend the inside tabs of the socket for a tighter fit...also be sure you are using bulb lubricant to properly seal the bulb in the socket...Both fits are imperitive to new bulb life, and moisture proofing your marker light. Be sure you have not mis-placed a rubber seal that goes around the socket to assure the marker light stays dry. You can make a replacement gasket for the seal by using a thin piece of rubber...ie (bicyle innertube) trace around socket for new o-ring seal, and cut out with scissors. Hope this helps.
Apr 02, 2012 | 2003 Volkswagen Passat
My black LG 24 builtin dishwasher has suddenly started leaking about 1/3 cup of water around the bottom vent on the door (LH side). How do I make adjustments to the door to stop this? I have already...
Check the door seal. To do this, make sure the door and the rubber gasket is complete dry. Apply a liberal amount of liquid detergent around the rubber gasket. Then close the door. Open the door and look for the liquid detergent to transfer onto the door. If there is a gap, then you will need to replace the door seal.
Jun 17, 2011 | LG Dishwashers
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
