Question about Pentair Minimax NT Heater
How to adjust pressure switch on mimimax 100 - Pentair Minimax NT Heater
  • jeff ross May 11, 2010
    millivolt or electronic? how old?
  • 139 Answers
Use a small allen wrench.you must also use a multi meter. if you are not familar with using continuity mode,i strongly suggest calling a qualified repair person.if not adj properly,htr can come on with pump off which could result in "china syndrome"
Posted on Jun 21, 2009
Pressure switch shut-off set too high.
It is adjustable. Remove the square cover nut and adjust the spring tension. . It would be best to lower to 110-115 psi. The compression rings will thank you for it..
Aug 24, 2014 | Campbell Hausfeld CW210500SJ Pressure...
Hydrostar manual
If it doesn't have a pressure switch, install one.
Nov 30, 2013 | Plumbing
Regulator outlet pressure too high ondd55146 type2
The pressure switch needs it's cut off pressure adjusted.
Feb 23, 2013 | Air Tools & Compressors
Switch will not shut off
Make sure you don't contact the electrical power inside the switch cover.
Make sure that you have an accurate gauge to test the compressor.
Adjust the switch to the original factory setting.
If the original setting was 100 psi, for example, make sure the gauge is reading at least 100 psi while the compressor is running. If the pressure is over 100, turn the nut that is over the larger spring counter clockwise until the compressor stops. This will lower both turn on and turn off pressures. The nut over the smaller diameter spring should probably not be adjusted.
Nov 26, 2010 | Square D 9013FHG14J52M1X Air Compressor...
Adjusting the pressure on the 2340-E
most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle
Oct 29, 2009 | Ingersoll Rand - Rand Type - 30...
MY COMPRESSOR ONLY PUMPS UP TO ABOUT 65 LBS. CAN IT BE ADJUSTED TO HIGHER POUNDAGE?
yes most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle back on.
Jun 16, 2009 | Air Tools & Compressors
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Pressure switch out of adjustment
Before you adjust the perssure switch, make sure that the intank check valve is not leaking pressure back to the pressure switch after it cuts off at 140psi. The check valve should hold pressure at 140psi. Follow the discharge airline to the tank to find the checkvalve (either chrome or brass with large cap). To check for leaking valve, run compressor till shut-off at 140, then unplug the compressor from wall and remove the 1/4 air fitting at the checkvalve and check for leak. If leaking, replace valve and leave the pressure switch at present setting. You should be good to go. Good Luck with your repair and email if you have questions.
Apr 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Pentair Minimax NT Heater Logo
177 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
