Question about GE 24 in. Profile PDW7880G Built-in Dishwasher
How do I recoat my microwave? - GE 24 in. Profile PDW7880G Built-in Dishwasher
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
I assume you want to paint it. Preparation is the key. Rustoleum has some pretty good products that look close to stainless steal. Clean the outside thoroughly. The paint will only stick well to metal surfaces. Plastics will tend to crack and peel. Tape and paper off all the parts of microwave not being painted. You will not want to get paint on labels, keypad, plastics or the door seal. Paint takes and hour to dry between coats. Practice with long strokes on something else first. Several thin coats is better than one thick one. Fumes can be strong. Outdoors without wind or a garage will be the best area to paint. Paint is oil based and you will need paint thinner( or WD-40 in a pinch ) for cleanup. I don't think painting would be wise inside the microwave. I painted my range hood, and I swear it looks like its stainless steel. I used the brushed nickel color. Good luck.
Posted on Apr 12, 2014
Orange peel pivot. When I spray polyurethane on wood
you will get peel if you use different brands or if you do not wait long enough to recoat. you have to to recoat within one hour if not then usaully 48 hrs. Hope this helps mike
Nov 28, 2014 | Cars & Trucks
Recoat a pan
Many grocery store department bakeries send their pans or trays out to get re-coated on a regular basis. Perhaps look up a bakery in your area
Oct 16, 2013 | Kitchen Appliances - Others
When i turn the microwave on the top of the appliance "arcs" i have not used since it has done this - called for a service call. anything i should do now?
unplug it so no one uses it by mistake, it probably has some paint off the cabnet behind the mica guard and the microwaves are arcing off the metal, it will need to be recoated with special microwave paint
Oct 20, 2011 | Viking VMOR205SS Microwave Oven
We left our telescope out on a covered deck. Now the mirror is badly pitted. can you grind it? or does it need replaced? (deep space hunter 10 ")
The mirror must be recoated -- the pitting is in the coating NOT in the glass--Google mirror recoating.
Here is one- http://www.opticwavelabs.com/
Feb 24, 2011 | Hardin Optical Deep Space Hunter 10...
Was cleaning inside of microwave and noticed the paint was bubbled and when I cleaned this area, all paint came off and metal was exposed 9about a 2 inch area). Should I use the microwave or will arching...
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
May 01, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I have a GE Microwave Oven/Dual Element Browner Model # JES1288SHO3. The inside cabinet is arching through the wave guide panel. DAVE IN LA.
Hi Dave in LA,
The wave gude cover is replaceable, the part number is1085082. The reason for arcing through is typically a splatter of food stuck to the cover and then the heating waves overcooked or burned it. Carefully replace the cover (panel), look for any burned spots behind the cover, if the wave guide is burned through, the Microwave is unrepairable. If the waveguide has small arc spots you can carefully clean (sandpaper) and use touchup paint to recoat. I hope this helps and if it does, please let us know!
Apr 18, 2010 | Microwave Ovens
Recoating my george foreman grill
The closest thing to what you are looking for is Secoa Technology - Dalton, GA Phone: 706-272-0133 Fax: 706-272-0135 You may need to call and see if they do recoating
Jun 03, 2009 | George Foreman GR30 Indoor Grill
I started my microwave and there was a corn kernal stuck underneath my rotating glass plate and it caught on fire and burned a small dentation in the bottom of the microwave. Can I safely run it? Can I...
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
It's safe to run in the very short term, but if you run it too long without fixing the blemish, it may arc and char more.
Nov 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Recoating the non stick surfaces of cook pots
yes there is it depends on your location, pls visit this site for info
www.thomasnet.com
cheers
Sep 13, 2008 | Faberware FSW343 Electric Wok
GE 24 in. Profile PDW7880G Built-in Dishwasher Logo
95 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
