Question about Cycling
How do you reset the odometer for new trip on Bell wireless odometer. there are 3 mode buttons bottom & 2 sides. Seems like it is all the same & none say reset.
  • 29 Answers
Pressing the right button should cycle the bottom display thru the functions--the current time, ODO (the odometer, showing the total mileage you've put on the bike), DST (the trip odometer - the one you're talking about), MXS (the maximum speed you've traveled on the bike). AVS (your average speed since your last reset) and TM (the time you've spent moving since your last reset). Some computers will also show the current temperature, the number of calories you've burned and the grams of fat you've burned.
Press the right hand button until you get to the DST display. Then press and hold the left button for about three seconds. The display should reset to 0.000.
If this doesn't do it (the display changes to MXS or something), cycle the display around to DST again and try holding one of the other buttons for a couple seconds. Holding one of 'em down should zero out the display.
Posted on Jun 18, 2009
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
How do you re-set oil mileage after changing oil in mini cooper?
If you do your own oil changes, this is a helpful tip to keep in mind. Typically, it is best to wait until your dealer maintenance service warranty expires, as an 'owner' reset could result in a missed oil change, particularly if the dealer checks the indicator it does not believe an oil change is due.
1. Locate the trip odometer button and depress and hold.
2. Insert the key into the ignition and partially turn into the first position.
3. Pay attention to the trip odometer to display the word 'RESET'.
4. Release the trip odometer button, then press & hold it again.
5. The 'RESET' message will flash.
6. Release the button, and then press & release again (once only)
7. The service interval is now reset to 10,000 miles
Dec 13, 2010 | 2006 Mini Cooper
How do you reset the change oil message on a 2007
Ford Explorer, Mercury Mountaineer, 2002-07
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the SET UP control to access the System Check mode. Press and release the RESET button to display “OIL LIFE % HOLD RESET NEW” is displayed. Press and hold the RESET button for 2 seconds until “IF NEW OIL HOLD RESET” is displayed. Press and hold RESET button until “OIL LIFE SET TO 100%” is displayed.
Ford Five Hundred, Freestyle, Mercury Montego 2005-06 Tap the ODO/TRIP button to toggle the display between the odometer and trip odometer. Tap on the ODOiTRIP button again to toggle the display between the trip odometer and OIL LIFE % display. Press and hold the ODO/IRIP button for 2 seconds or more to display OIL LIFE 100%. Your oil life in now reset.
Jan 06, 2010 | 2003 Mercury Mountaineer
Changed oil and message center still says oil change required (2002 mercury mountaineer)
Ford Explorer, Mercury Mountaineer, 2002-06
Nov 03, 2009 | 2002 Mercury Mountaineer
How do i reset the oil ligt
Oct 31, 2009 | 2006 Ford Explorer
I have a 2008 corolla. It has an auto light when the car needs an oil change. I need to know how to reset it.
Look in your owners manual and go to the part that explains the different symbols on your dash. Look for that service reminder and it should tell you what page to go to to learn more about that. Somewhere there should be some wording to the effect that "When you have your car serviced by a certified Toyota dealer they will reset it for you. In the event that someone other does your maintenance then this is the procedure to reset......."
Oct 04, 2009 | 1998 Toyota Corolla
How can I get rid of the messages on my board....(ie. regular maintenance due)
1. Press and hold trip odometer reset button 2. Turn ignition key to run position KPII (not the start position)
3. Wait 30 seconds or until service light "!" begins blinking
4. Release Trip Odometer button
5. Turn ignition to off position
If that doesn't work try:
2. Turn ignition key to run position (not the start position)
4. Turn ignition to off position, the service light continues blinking
5. Release Trip Odometer button
should reset it for you
Jul 03, 2009 | 2003 Volvo S60
Bell f20 resetting trip odomoter DST
Did an obsessive search of this problem and found this: "Right Button" . . . click to display the "DST" (distance) than hold the "LEFT Button" for 2 seconds. YEAH!! Reset trip ONLY!! This problem is simply an error in the instruction manual. ~G~
Jun 01, 2009 | Bell Sport & Outdoor - Others
How do i reset my kilometer gauge after changing oil or does it reset to 0 automaticly
Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
5. Watch for the word “RST” to appear on the Odometer indicator.
7. Wait for the “RST” message to fl ash.
Apr 12, 2009 | 2003 Mini Cooper
Mini dash
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
backbutton0001.gif Article Date: Jan 02, 2007
Car Accociations: NEW_MINI
Hits: 16731
Jan 13, 2009 | 2002 Mini Cooper
Cycling Logo
341 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
