Question about Garden
How to install a carburetor for a Huskvarna 917.375820
    Problem Solver:
  • 29 Answers
Maybe this will help..http://www.ereplacementparts.com/husqvarna-917375820-200601-lawn-mower-parts-c-114486_118261_118492.html
Are you wanting step by step instructions for replacing it? Do you already have a replacement? if no, that link will help with that.. Best of luck.. Let me know what exactly you need and I will do my best to help..
Posted on Apr 13, 2014
Huskvarna 225L weed trimmer weak spark or fire's every 2 or 3 pulls! Any suggestion?
If you have intermittent spark, your coil is going bad... time for a new one. Amazon sells an aftermath for a good price. Try this, remove the plug, spray carb cleaner in the hole, then install the plug. Give 2 slow pulls, then pull normally. If the unit starts for a few seconds, your problem is the carburetor.
Oct 03, 2015 | Garden
How do I connect the throttle to the carburettor on la125100 series
THis provide that it still the Briggs 331877 on it
Install Carburetor
NOTE: Always replace air cleaner gaskets and carburetor mounting gaskets any time the carburetor has been removed for service.
1. Position new gasket on studs with long edge of gasket opposite fuel inlet of carburetor.
2. Hook governor spring in throttle lever hole without grommet. Hook governor link in throttle lever hole with grommet.
3. Hook choke link into outer hole of choke shaft from underneath. Slide other end of choke link into slot in governor control bracket.
4. Position carburetor on engine. Install Carburetor to intake screws or nuts and torque to 70 in- lbs
5. Connect fuel hose to carburetor and secure with hose clamp.
6. Using new gasket, install air cleaner assembly to carburetor.
Adjust carburetor, if applicable.
7. After final carburetor adjustment, use Knockout Pin #19135 to install new limiter cap with flat side facing up.
Jan 08, 2015 | Garden
No spark on Huskvarna Rancher 55
disconnect any and all kill wires going to the coil... if you still have no spark then it can ONLY be the coil... if this produces spark then you have a kill system problem or your flywheel has no magnetism... and this can be the only solution as you do not have points/condenser or things just went full derp
Aug 27, 2014 | Garden
No spark with Huskvarna Rancher 55. New coil
anon re connect the kill switch. If this fail try connecting the two ends of the wire to the kill switch together.
Huskvarna Rancher 55 (~2000) no spark
could be in your switch. the ground wire needs to be attatched for new coil to work
Aug 26, 2014 | Garden
I have a huskvarna 254XP and I contiue to break the pull cord after 3-4 starts, I must be replacing the cord wrong. what is the proper installation of the pull cord?
The cord ends need to be melted somewhat, then an overhand knot tied to retain both ends. If the cord is breaking along it's length, the cord may not be heavy enough--check with a local saw service shop for the correct cord and buy about 1-meter of length to make sure that you are not reaching the end of the cord when pulling on it. Make sure there is nothing that the cord passes over to damage the cord causing failure. Hope this helps!
Nov 12, 2010 | Husqvarna Garden
Do I have to use ethanol free gasoline?
It had better do so--or any saw brand that fails to run on ethanol blended fuels will see sales fall rapidly in the USA. We, personally, own one of these same saws which (when new) ran great for about 3 days, then refused to start. A trip to the warranty repair station got us a new ignition module. After return, it ran for about two days, then would not start again. The warranty repair then installed a replacement carburetor and about a year later, still seems to be working fine--it's a great hard working saw when it operates correctly. Good luck!
Jul 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My leaf blower will start but wont run when i give it gas it dies. Huskvarna 125B
fuel system needs cleaned
check fuel lines
filter
remove carburetor for replacing diaphragms/gaskets
Nov 08, 2009 | Husqvarna Garden
Huskvarna Viking quilters 850 I keep getting
it is a problem your tech can fix, ( should have been done when he had the covers off) but take it back in and tell him to adjust the sensor on the cutter so it doesn't rub and to clean the sensor. this will fix the problem
Oct 20, 2009 | Husqvarna Viking 1
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
