Question about Echo REPOWER TUNE UP KIT PB-46HT 46LN 60HT 600 601 602 - ECP 90067
No fuel to carb
C/out a rebuild to the carb and replaced the fuel filter but i get no fuel to the carb what could it be.
    Guru:
  • 145 Answers
You rebuilt the carb? could the metering diaphragm be installed upside down? (THE ONE WITH THE DISC) or could it be the lever connected to the needle isn't set to correct height? Zama and Walbro have great web sites. one more thing are you sure you put the fuel lines (2) on the right spot?? one line goes to the filter the other is simply a return and only goes in the tank but not too deep into the fuel
Posted on Apr 13, 2014
Sportsman 90 idles wont rev
Replace spark plug (gap correctly),Drain all fuel, replace fuel filter, replenish tank with fresh fuel, do a thorough readjustment of the carb settings (last resort - remove and rebuild carb)
Feb 17, 2015 | Polaris 2008 Sportsman 90
Replaced fuel filter on my John Deere LA120 and now it smokes and will not go to full throttle any ideas on how to fix the problem?
you got dirt in your carb when you changed fuel filter you always have to clean fuel filter before you replace it have to rebuild carb now no choice rebuild it
Sep 09, 2014 | John Deere Garden
Has sprak and new fuel pick line, filter ,carb still will not run
Clean carb and or replace diaphrams and needle or replace carb, sometimes it's cheaper to replace carb than to clean/rebuild it
Dec 01, 2013 | Stihl Bg 55
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
Mower only runs for 5 sec with ether after carb rebuild
look on 'you tube ' and see if anyone is rebuilding one to watch
Apr 07, 2012 | Garden
New battery, new starter & still problems starting
Hello! How long have you owned it? Question is directed at the carb and fuel pump...I would suggest rebuilding the carb with kit and replacing the fuel pump at the same time...see photos below...There are a couple of different fuel filters; one for a non- fuel pump (gravity feed) and one with a fuel pump...Your engine requires the fuel pump filter...dirt and varnish build up in the carb and pump especially if the wrong filter is installed...Buy a gallon of carb cleaner with the tray inside...
Guru...saailer
Genuine OEM Part - Manufacturer #808656...$18 Fuel Pump
Genuine OEM Part - Manufacturer #691035...$6 Filter
Genuine OEM Part - Manufacturer #797890...$45 Rebuild Kit
Feb 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Chainsaw will only run with choke on. Carb cleaned, air filter cleaned, fresh fuel.
If engine has poor compression, there won't be enough vacuum to pull fuel into engine. Test for proper engine compression with a compression gauge. Unfortunately, problems like a scored cylinder wall can happen, which will cause poor compression, which causes poor fuel delivery.
Assuming that the carb is clean, make sure there are no vacuum leaks where the carb meets the engine. It's a good idea to get a carb rebuild kit and replace carb-to-engine gasket(s).
Note that there are often small vacuum passages in the carb that are easy to miss when cleaning/rebuilding it. Also, if someone fiddled with the mixture-adjustment screws, they may need to get readjusted.
Make sure fuel inlet screen or filter is clean, and that air-vent into fuel tank is clean. Without spilling fuel everywhere, see if it will run with fuel cap loose or off...this happens if the air vent is blocked.
Oct 21, 2010 | Garden
I have replaced the fuel lines on flymore maxi trim 380
Sounds like a fuel delivery issue....pull and clean spark plug or replace it...remove and clean carb....check fuel filter, make sure its not clogged.
It may be time to rebuild the carb if cleaning it doesn't remedy this condition.l Rebuild kits aren't real expensive and sometimes fix this type of problem.
Jul 09, 2010 | Electric Garden
1997 yamaha waverunner 3
My 97 gp760 did this. I checked almost everything. Replace or clean your plugs, then run carb cleaner through your fuel filter both ways, and then spray carb cleaner into the fuel line from the fuel filter to the carbs. Run 10 minutes, more carb cleaner into the fuel line, and run it 15 more minutes. Then zip tie fuel lines at the fuel filter. I figure there was trash or buildup in the carb. Its easier than rebuilding the carb. Try it. Daniel at the MEXPIPE Pto Escondido Oaxaca.
Jul 26, 2009 | Yamaha 12V Air Pump
Echo REPOWER TUNE UP KIT PB-46HT 46LN 60HT 600 601 602 - ECP 90067 Logo
102 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
