Question about Kitchen Ranges
Back burner caught fire
Hi there!
The other day while I had the burner and drip pans off my stove to clean the stove top, a tea pot full of water accidentally spilled on top of the stove top and into the holes left open by the burner being removed.
Today my back burner caught fire while I was cooking. Is there any correlation? Also my drip pans are pretty gross and had planned on replacing them anyway. Could the drip pans have caused the fire?
thanks.
  • miznyc Jun 17, 2009
    lol. thanks. *off to get new drip pans*
  • Marvin
    Marvin May 11, 2010
    yes, you proved once again that grease is able to burn.
  • 82 Answers
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Posted on Jun 18, 2009
Need to know why burner flames on Viking stove with cook top over shoot the bottom of the pans once the pan is placed on burner top.Second the oven door was repaired By technician does not close 100%
pots to small for burner adjust flame size to fit pot placed on
oven door is frame adjustment you need servicer that is familiar with this repair
Jan 04, 2018 | Viking Kitchen Ranges
I had a pot of water boil over and the stove top turned off. How do I turn it back on ?
Probably just got too wet in the burner or igniter. Give it a day to dry on its own or light it with a match to dry it with its own heat.
Dec 29, 2014 | Kitchen Ranges
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Tappan self cleaning oven
You plobably have the incorrect drip pans that do not have the proper holes for the grates to fit in, I would chech with an appliance repairman, he should have a source for the correct drip pans.
Aug 14, 2013 | Ovens
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
Sep 22, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Need to know if the burners come out of my stove
Hi, The burners should pull up and out. They plug into a receptical and should release fairly easy.
While you have the burners out, check the ends and see if there is any sign that they have been burning/arking. Thet should be clean before putting them back in. I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Replaceing glass top on a stove
The top can be replaced but it is expensive. Your range is less than a year old call a local servicer to see if there may be warranty available to cover this problem it may not cost you anything. Good luck.
Jan 15, 2009 | GE JBP64 CleanDesign Electric Kitchen...
Stove top burners on glass stove seem to have a governor on them
My initial attempt at solving the problem was to contact the GE customer service phone line.  When I explained the problem, the representative had no clue how to solve it, and referred me to the service organization.  The representative at the service organization was equally clueless, and suggested scheduling a service call at $100 plus parts and labor.
This is all quite disappointing; these customer and service representatives obviously have no training in solving the simplest of problems.  This is okay if GE's goal is to maximize service revenue.  But, I can tell you I would be very unhappy to have a technician visit my house, for $100, only to be told I was using a pot or a pan that was designed incorrectly for a glass cook top.
I solved the problem by going to the web site www.geappliances.com, opening the user manual, and looking under trouble shooting.  The first problem mentioned is exactly as described above.  The problem is inappropriate cooking appliances.  It is not possible to transfer heat efficiently if the pot you're using has a rim or lip on the bottom.  That is, the pot must sit flat on the glass cook-top, it cannot be raised off the cooking surface by a lip that elevated the pot from the surface.  These pots are designed to be used with gas flames, not a glass cook top.
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
286 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
