Question about Roadmaster (VR500CSBT)
After installing the unit the face will not light up or come on the two buttons over and under the volume button will light up
I got the adapter for wiring for my Chevey and wired the other as directed
  • 24 Answers
Double check the red..yellow and ground wires..sounds like your not getting power.. check fuse in unit itself.. when installing any component in a vehicle..triple check and use things like solder and shrink wrap..always remove negative cable from vehicle battery prior to starting work or adjustments .also prior to removing cable from battery..reference owners manual.. some vehicles need to be disconnected a certain way to avoid future electrical and drivability problems..also ensure faceplate is secure
Posted on Apr 14, 2014
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
Jun 21, 2012 | Blaupunkt RPD-545 CD Player
Sk4000 remote will not pair with headset, tried everything and checked with support. They said be sure and pair remote before pairing phone. Tried that and still nothing. if the remote is no good there is...
If you have verified that the battery is good in the unit, try this (from the folks at Parrot). The HCU is the main control unit.
1) Turn the HCU on
2) Clear the memory on the HCU by holding down the power button and accept call button (the two large buttons on the face of the HCU)
3) Wait until you hear the HCU make the request "please pair device"
4) Hold the volume up and the volume down keys on the remote for 15 seconds
5) Release the buttons on the remote.
It might be fixed now. Press the switch on the bottom of the remote to switch to radio and see.
Jun 09, 2011 | Parrot SA Parrot SK4000 Motorcycle...
For acer 5570z the problem i face is "No wireless
make sure the unit does not have an external power switch for the wireless card or a button combination to enable the card. you can also check to make sure the driver for the device is properly installed by
1. right clicking on the my computer icon >
2. click properties
3. click device manager
4. click network adapters
make sure a device is listed with a description similar to "wireless lan adapter b/g"
Mar 05, 2011 | Acer Computers & Internet
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Pioneer DEH P4100 Volume Stuck
if all you need to do is get the cd out there is a small hole in the foront of the unit just big enoufe for a papper clip just stratien one out and put it in the hole but if you want to fix your unit then you will have to take the face plate apart get the soda out of the face plate i always use glass cleaner and cotton swabs for this just make shure you get any and all residue off before you put it back togethr and make shure you clean the rubber pads under the buttons and you should be good to go
Oct 09, 2008 | Pioneer DEH-P4100
Volume buttons
Hello Gavrilov,
As I understand that you are facing issue with the Qucik Touch buttons of the volume on the notebook.
If this is correct, install the Quick Touch buttons drivers on the notebook.
Here are the drivers for Quick touch buttons:
Windows XP:
ftp://ftp.hp.com/pub/softpaq/sp29501-30000/sp29528.exe
or
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39425.exe
Windows Vista:
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
Sep 11, 2008 | HP Compaq nc6120 Notebook
Display
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
RE: VOLUME BUTTON POSITION ON FACE OF UNIT
if there is a knob rotate it clock wise / to the right, to increase the volume, & anti clock wise to the left, to decrease the volume.
there may be buttons with this symbol ' ^ ' or ' + ' means volume up, there may be a ' - ' or ' v ' to decrease the volume.
or this one ' > 'can also mean up & this one ' < ' can mean down.
Hope this helps?
Dec 15, 2007 | Car Audio & Video
Wireless Adapter not working under Vista
when you say the radio button does not light up, are you refering to the light on the front of the notebook?, if so you can turn the wireless on and off by the little slider switch next to the light.
Sep 21, 2007 | Acer Aspire 5050-3242 Notebook
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Roadmaster (VR500CSBT) Logo
53 people viewed this question
Top Roadmaster Car Audio & Video Experts
xxxxxx xxx
Are you a Roadmaster Car Audio and Video Expert? Answer questions, earn points and help others
