Question about Vizio Televison & Video
3 Thin blue and red lines on vizio right side
They are there all the time. If you flex the screen they get smaller.
    Top Expert:
  • Vizio Master
  • 74,666 Answers
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel is given. You can see and compare it to that of your TVs, and can make sure.
Posted on Apr 13, 2014
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
SOURCE: green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Posted on Sep 28, 2008
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
  • 1587 Answers
SOURCE: thin blue line down middle of screen
The red line driver at that point isn't working or there is a bad connection to the panel for that line. (I assume the intensity and hue of the cyan line varies witht the picture). What type of screen is it? Plasma or LCD? The following is for LCDs and may not apply to plasma panels. (I haven't had to fix those yet.)
Once in a while you can solve the problem on an LCD by gently massaging the connector to the display panel edge at the bad spot, although there is a risk of causing other lines to drop out. I once fixed an LCD that had a hair caught between the elastomeric connector and the display glass, but if that were the culprit in your case, you'd probably be missing more than one line. It could also be a problem with the driver chip for that line.
Be very careful about tearing into the LCD. The connections are very delicate, the fluorescent backlight tubes are glass and have mercury inside, and the potential for electrostatic discharge damage is always a concern. It's easy to cause more problems than you fix when you get into the connections, although those can usually be reversed with patience and steady hands. The worst case is a misalignment that would mess up your color registration (color drive going to the wrong line). Most panels have a sticker inside warning against removing the driver electronics. It's there for a good reason.
If I've scared you off, or if the connector massage doesn't work, there are companies like Moniserv that specialize in repairing LCDs. They have the equipment and dust-free facilities needed to repair bad panel drivers.
Posted on Mar 23, 2009
SOURCE: Thin Red Line on LCD TV
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Posted on Jul 07, 2009
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
Brand new 55" led Emerson tv has s thin red blue green line(one line)verticle on right side of screen? What to do?
If it does not disappear in a little while, just ask the shop repair or bring a new screen. Must be a guaranty case.
After installing my computer screen, I had vertical lines in the middle, but after some time (In my memory about a few hours) they all disappeared and never came back.
Jan 06, 2015 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
I bought an Olevia 47" HD LCD flatscreen about 1yr ago. I moved to a new apartment and when i set it back up, there is now a RED LINE GOING DOWN THE RIGHT SIDE OF THE SCREEN ALL THE TIME. IT APPEARS THAT...
This can happen due to flexing of the screen when being moved. You should always ship using the original packaging. Also some are supposed to be shipped in a particular orientation. If its just the connections that are slightly out it may come back after a while
Aug 30, 2009 | Olevia Televison & Video
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Lines on screen
laptops do not have degausing thats only on rct screens what you have is a pixil problem and the lcd or plasma is in need of repair or replacement, if your laptop is under warrinety i sugjest you bring it in soon.
Sep 13, 2008 | Dell Inspiron 2200 Notebook
Vertical Lines on Acer Aspire 5100
sounds like your viedo card is about ready to a dump my need to download a new catlist driver lala linda
Aug 23, 2008 | Acer Aspire 5100 Notebook
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
