Question about GE JVM1650 1000 Watts Microwave Oven
Top cabinet template for jvm1650cb006
Need top cabinet template
2 Suggested Answers
SOURCE: GE JVM1650CH01 Microwave Template
I have this microwave and it shuts down constantly. I'll never own another GE.
Posted on Nov 09, 2012
I need the top cabinet template for GE microwaveJVM1950DRCC
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
May 17, 2016 | GE JVM1950DRCC
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Where can I find a top cabinet template?
Samsung might be able to supply one.
Jan 03, 2015 | Samsung SMH2117S
I need the Top Cabinet Template and the Rear Wall Template for GE Microwave Model JVM2070WH02
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 24, 2013 | GE JVM2070 Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Need top cabinet template for ge spacesaver microwave-jvm1440whq2
You can download GE owner's manuals and installation instructions here.
If it;s not there, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jun 06, 2009 | Microwave Ovens
I have a Ge spacesaver model #JVM1350 microwave that I picked up at a sale, and was wondering when installing if the bolts on top go directly thru the cabinet bottom or is there a bracket? Thanks
I assume you also have the wall mount plate with your oven.
That wall mount carries the bulk of the ovens weight and you normally do use the long screws to bring the front of the oven up to the bottom of the cabinet above the unit. Filler blocks made to fit and to the correct thickness ( to fill the gap between the bottom of the cabinet and the top of the oven) are usually made so that the oven 'nests' snuggly to the underside of that cabinet. Without templates to get holes properly lined up.. they aren't that easy to locate the clearance holes in that cabinet. You can get user manual and installation details at this GE website..
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Hope this helps..
Sep 05, 2008 | GE Microwave Ovens
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
23 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
