Question about Kia Vehicle Parts & Accessories
High pitched sound from the front when I turn on the car and disappears upon driving. I just had the powersteering pully replaced. Help! I have a 2005 Kia Amanti.
High pitch sound when i turn on the car. just had the power steering pully replaced. any ideas?
  • 29 Answers
Could just be a loose belt
Posted on Apr 13, 2014
3 Suggested Answers
SOURCE: high pitched squeal when starting car
Sounds like a belt, and possibly the one on the power steering pump which may be the sepentine belt. Could be caused by power steering pump pulley resistance or the belt tensioner bearing. Try a visual check with motor running. Be careful of moving parts!
Posted on Jun 06, 2012
  • 2210 Answers
SOURCE: The steering wheel on my 2004 Amanti hangs up and
I know its obvious but is the system topped up correctly?
Posted on Nov 26, 2013
High pitch whistle sound on my 2005 saturn ion whenever my car is on, whenever it is in idle or in drive
start in the engine bay
look from air filter to throttle body for any air intake leaks
if it is supercharged listen to the supercharger bearings
then anything spinning at high rpm from the serp belt
could be a bearing water pump or idler pully
if internal only could be something caught in the air vents
Oct 12, 2016 | Saturn Cars & Trucks
Hyundai accent 2005 when starting up the vechile and driving there is a constant ugly sound coming from the front passenger side wheel and when applying the brakes on there is a high pitch squeel
That screeching sound is a warning that your brake pads are worn down to the point where they should be immediately replaced. If you do not replace the pads, you'll score the rotor and incur an additional expense. Remember to replace the brake pads on both sides, i.e., driver and passenger side.
May 01, 2012 | 2005 Hyundai Accent
I have a high pitch wine in engine and it increases as RPM goes up sound like right side by fire wall 85000 on car.
I had the same thing and it turned out to be a bad Idler pully which eventually went bad and tore up the belt. note one bolt on the idler has to be reached from underneath the car.
Nov 22, 2010 | 2005 Dodge Caravan
I hear a high pitch sound in the engine compartment that starts when I start the car. With the car still in park, the noise does increase when I step on the accelerator. While driving the noise is in sync...
sounds like you need to replace the idler pully and maybe the tens. pully. and that will solve your sounds problem. whats happening is the bearings are bad and thats what you hear
Apr 06, 2010 | 2005 Nissan Altima
Mazdaspeed protoge 03 is making that high pitch squeeling noise and i just replaced powersteering belt.also as soon as i turn a/c on it starts squeeling
That means the fanbelt on the alternator is not tight enough or needs to be changed, if the belt on powersteering goes via A/C than it might be too tight on the powersteering pulley.
Jan 22, 2010 | 2003 Mazda Protege
How to locate the tension pully in 2005 toyota corolla?
look for the free wheeling pully on the front of the engine that not connected to anything like your a/c pump or alternator,powerstering pump, etc.
Nov 06, 2009 | 2005 Toyota Corolla
High piched whine on left front! 2001 dx
hat u need to do is drive vehicle until you hear this pitch once you hear it turn steering to the right to see if whine disappears if it does you are looking at replacing wheel bearing.
Feb 26, 2009 | 2001 Mazda MPV
High pitched car sounds
does the noise and light occour at the same time ? another cause of a high pitched noise can be slipping drive belts, alternator,powersteering etc so check them for tightness, condition etc, does the noise happen when car staionary and just rev the engine ? if so i would say it is the drive belt/s, go back to the VW dealer re the ABS light and get them to check the OBD as should be done as part of the service , hope this helps
Mar 29, 2017 | 2001 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
98 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
