Question about Mantis 2-Cycle Tiller
Runs only with the choke more than halfway closed
Starts fine but needs the choke to be closed
    Scholar:
  • 115 Answers
Adjust the carburator, it is running to lean.
Posted on Jul 04, 2009
00 polaris 90 scrambler wont start first time unless you use starting fluid after that your all right it start fine it has a electric choke?
check the operation of the electric choke as it may not be properly adjusted to be closed at first start
chokes(manual or otherwise) are held open until you open the accelerator/throttle to release the cam lock to allow the choke butterfly to snap closed
the problem will be in the choke area of operation
Feb 08, 2016 | Great Office Equipment & Supplies
My 1969 GTO takes forever to start in cold weather, once it catches and warms up it runs fine
Assuming the engine is in good shape and not in need of a major tune-up, check your carburetor choke. It's not closing when cold. Clean and adjust.
Get a service manual and follow the instructions. Far too complicated to cover here.
Also, make sure you know how to properly SET the choke on a cold start. Slowly push the gas pedal to the floor and let up. Start engine without touching gas. If it's REALLY cold, like 0 degrees, you can hold the pedal halfway down while starting, after setting the choke.
Feb 06, 2014 | Pontiac GTO Cars & Trucks
My 4 cycle BP blower will run with the choke halfway, but not fully opened or fully closed. The throttle will not increase speed, either. What would you suggest? It takes a good 5 minutes with choke...
The carburetor needs to be cleaned and/or adjusted so if you do that, you may as well install a low price gasket and diaphragm kit in it. This will alleviate all the problems that you mention. I don't know your model number else I could give you the part number for the carb kit to install. This solution works most of the time.
Sep 06, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
My MTD Yard Machine Y2500 starts fine and works with the choke partly closed. It also idles fine with the choke fully closed but stalls when I press on the throttle when the choke is fully closed.
when the choke is fully closed your choking the fuel out,, thats why when you give i t gas it dies , its not supposed to run with the choke on and getting fuel , use the choke only until the motor warms up to operating temp,, then open it,, and you should be fine,
Jun 01, 2011 | Mtd Garden
I have a 1994 cadillac eldorado. Sometimes when I start my vehicle and begin to drive; it starts to shake. When I get past 10mph the shaking stops, but when I conduct a complete stop; the vehicle starts...
You need to check the choke on the engine for cold starts it chokes off air to the fuel mix . if it is closed to much the engine will want to die and shake. When the car warms up the choke opens and the car gets air and runs fine although the choke could just be part open. It still will need adjusting.
Hope this helps
Mike
Jan 27, 2018 | 1994 Cadillac Eldorado
Hard starting on a Makita line trimmer? How do I solve this issue?
Try pushing the primer 8-10 times hold the throttle wide open and turn choke too full.when it starts it will probably quit turn choke to halfway and start again.should stay running.If that don,t work carb needs to be rebuilt or replaced.
Nov 29, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Mantis 2-Cycle Tiller Logo
213 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
