Question about Nintendo Guitar Hero Wireless Guitar - Wii for Wii
Cord is cut - Nintendo Guitar Hero Wireless Guitar - Wii for Wii
  • 3,320 Answers
Fix the cord, take it to a repair shop, buy a replacement.
Posted on Apr 13, 2014
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
Black and decker as185-2
it's time to cut the cord shorter. Disassemble and cut out the bad part of the cable and either marrette or add crimps etc to put it back together... or get a new cord cap.
Oct 15, 2013 | Garden
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
How do I put a light switch on a extetion cord
You want a light switch on extension cord.
What kind of light switch do you have? You posted under GFCI device which is totally different than ordinary wall switch.
And what type of extension cord?
Add a comment with more information.
If ordinary light switch is installed on 3-wire outdoor extension cord:
Slice open the side of cord and you see 3 wires: black, white and green.
Cut the black wire in half and connect each end to brass screw on light switch.
If ordinary light switch is install on indoor 2-wire extension cord.
Look at plug and notice there is a wide blade and narrow blade.
Narrow blade is hot. You want the wire connected to narrow blade.
Cut that wire in half, but do not cut other wire.
Connect each end of wire to brass screw on light switch
If you want to install line switch onto indoor 2-wire extension cord:
Narrow blade is connected to hot wire.
Open line switch.
Connect each end of black wire to brass screw. OR if no screws, then place cut wire in open grooves.
Tuck other wire into groove and then reassemble switch.
Jul 05, 2011 | Leviton 8299 Combination Switch / Smart...
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Fix a cut power cord
get a electric tape then roll it to the cut cord and then it will fixed for several days
Jan 17, 2010 | Aspen Refrigerators
Cut Cord
Please specify. What did the cat chew the wire to?
Jun 20, 2017 | Logitech Premium Headset
Nintendo Guitar Hero Wireless Guitar - Wii for Wii Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
