Question about Visual Land Prestige Pro 10D 10" 16 GB Wi-Fi Pink Tablet Android 4.2, LCD Touchscreen, 1024x600, 8 Hours
Have had it 2 days. Plugged it in to charge and now it wont tuirn on.
Would like to know what to do
  • Visual Land Master
  • 3,320 Answers
Warranty replacement.
Posted on Apr 13, 2014
My Dragon touch A1x Plus got hot on a window ledge, and now wont turn on, and if I try to charge it I just get the battery symbol with no percentage
Don't know if this will work but put it in a cold place for couple days then re-try, don't mean freezer tho lol.;
Aug 09, 2016 | Dragon Touch Tablets & eReaders
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
What does the lightning bolt inside the battery symbol mean on the screen of the digiland tablet dl700. It wont charge
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
Feb 04, 2015 | Tablets & eReaders
My tablet wont charge
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
Why mmy kocaso tab woont turn on
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
Why wont my kendle modle no do1400 hold a charge
Does the kindle work when you have it plugged in? It could be that the charging port is broken. These models are notorious for broken charging ports.
Jul 16, 2014 | Amazon Kindle Wireless Reading Device
My irola dx752 tablet will not turn on. I just got it for Christmas. I had it plugged in to charge. I have tried charging it both with the USB cord and the AC cord. I do not know what to do.
HI Jessica,
please let it charge 10-20mins to pop up the battery voltage level.
if it is not turn on anymore please go fore the warranty replacement.
regards.
nuwan
Jan 08, 2014 | Tablets & eReaders
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Jun 05, 2013 | Samsung Tablets & eReaders
Le pan tablet wont charge how to reset
Le pan tablet not charging after all night does not show battery when plugged in.tablet does turn on battery level about 30%?
Apr 28, 2012 | Tablets & eReaders
I have been trying to turn on my galaxy tab but it just wont turn on. I have tried charging it for a full day but still nothing. i dont even know if it is charging.
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
Apr 30, 2011 | Samsung Galaxy Tab Tablet PC
Visual Land Prestige Pro 10D 10" 16 GB Wi-Fi Pink Tablet Android 4.2, LCD Touchscreen, 1024x600, 8 Hours Logo
90 people viewed this question
Top Visual Land Tablets & eReaders Experts
Steve Mason
alex metro
alex metro
Lawrence Oravetz
Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
