Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Bike does not run when warm,
Acts like it is fuel starved is an 883,
  • 48 Answers
Check fuel filter and tank fuel valve screen if ok drain float bowl and flush out most likely dirt in one of these
Posted on Sep 28, 2009
  • 40 Answers
Ignition module most likely; what year? is the module in the "cone" on the cam cover? if so, as the bike warms up the "solid state" module in there most likely has an electrical break somewhere that only surfaces when the bike warms up and expands all the "jelly"...very common!
Posted on Jul 07, 2009
Fuel is flowing and I have spark but when the engine warms it acts like it fuel starving only running on 2 or 3 cylinders?
Have you done a compression check, all 4 cyl should be within 20% of each other...
Not sure with that year but ignition points can be fouled. It bike has been sitting for 3 or months the pilot jets can be blocked. Carbies can be out of sync..
Happy to help you out if you want...
Sep 05, 2013 | 1979 Honda GL 1000 (K3)
Car dies after it warms up, no pressure in radiator when i remove cap, and acts like it's starving for gas
Some of the information does not correlate.
If there is no Pressure, then you Radiator Cap is Bad
Stalling or Starving for Gas can be a Fuel Pump or Air Filter
Remove the Air Filter and see what happens.
Test the PRESSURE of the FUEL System
Apr 10, 2013 | 1993 Dodge Dynasty
Bike acts like its starving for fuel in 4th and 5th gear
Hi Flashgordono, and the usual suspects are:
1. Idle speed improperly adjusted.
2. Intake manifold air leak.
3. Restricted fuel tank vent system.
4. Dirty or damaged air cleaner element.
5. Enrichner valve not seated or leaking.
6. Restricted fuel supply tract.
7. Plugged bowl vent or overflow tube.
8. Worn or damaged needle or needle jet.
9. Loose or plugged fuel and air jets or passages.
10.Vacuum piston assembly malfunction.
11. Loose or plugged main jets or passages.
12. Improper float level.
13. Accelerator pump inoperative.
Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 07, 2012 | Harley Davidson Motorcycles
1985 toyota 22RE fuel injection problem
Try Oxygen sensor or maybe throttle position sensor.
Feb 06, 2012 | Cars & Trucks
I have to keep pumping the gas pedal to keep the engine running, it acts like it is starveing for fuel.then after it warms up a bit it will run at an idol. then when i step on the gas pedal it boggs down...
2 things to try-
first- change fuel filter(maybe this- is cheap)
second-more likely given what you said- partial melted catalytic converter-
when it warms up- passage expands enough to let it run a little
Jun 03, 2011 | 1987 Ford F 150
Truck acts like it is running out of gas? Replaced fuel filter. Ran fine for awhile but now still acts like it is starving for fuel.
my '93 f-250 (4.9L) stopped running while driving, now it acts like it isn't getting any fuel. Tried switching tanks, but still does the same. What would be the problem.
Aug 17, 2010 | 1993 Ford F250
Engine surges when cold - Once it warms up it runs fine
If carburated, I would suspect a sticking choke, making the fuel mix way too rich.
Jul 02, 2008 | 1997 Jeep Cherokee Country
Lands Phones Logo
115 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
