Question about Jobar RX Optics 35 MM Negative and Slide Scanner Digital Image Converter JB5323
I need software for Jobar JB5323 slide and negative scanner for my new laptop on window vista
I need software to downlaod.
Need an driver update to Windows 7
Most VISTA software and drivers will work with Windows 7. If you get an error trying to load it, it may be because the installer looks for the OS identifier and it is not XP or VISTA. IF that happens, you can right click on the installer file/icon, and select "compatibilty mode" for VISTA to attempt to make it work. This is rarely necessary, however.
Aug 31, 2016 | Jobar RX Optics 35 MM Negative and Slide...
Is there a driver for Mac OSX (10.11.3)
The manufacture would be the primary source if a driver does exist.
Apr 04, 2016 | Jobar RX Optics 35 MM Negative and Slide...
Installed the JB5323 Jobar Slide & Negative Scanner into a Window's 7 Professional contained in my Dell and it will not give me all the different things it has. It won't convert the negative...
You don't need any special software or hardware to do this, and it's really easy too! Open one of the saved image files of the negative scan using Microsoft Paint. It's under Start -> Accessories.
Now click select in at the top, and then right click anywhere on the image. At the very bottom of the menu, there should be an 'invert colors' option. Click it. Your negative should now be a normal picture =).
Sep 10, 2011 | VuPoint FSC1VP
I need software for iconvert software for a scanner I bought at brookstone. It did not come with a cd. Please help me
I had the same problem I found that the missing CD is downloadable on the Brookstone website.
http://brookstonemanuals.com/
Product number for Brookstone "Slide and Negative Scanner" is 598581 ... see back of your manual to confirm.
iConvert Film & Slide Scanner (598581) iConvert Film & Slide Scanner Drivers for Windows XP & Vista (119 MB)
Worked great for me!
Dec 31, 2010 | Office Equipment & Supplies
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
My Mom purchased a Jobar's slide & negative scanner by RX Optics
install for scanner for umax astra 2500 for windows 7
Mar 29, 2010 | Office Equipment & Supplies
Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
Dimage dual scan 4
Use VueScan instead of the Minolta software. A free trial is available so you can test it before you commit to buying it. Available for Windows Vista.
http://www.hamrick.com
Mar 29, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Jobar RX Optics 35 MM Negative and Slide Scanner Digital Image Converter JB5323 Logo
419 people viewed this question
Top Jobar Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Jobar Office Equipment and Supply Expert? Answer questions, earn points and help others
