Question about Samsung Washing Machines
What does error code dE mean on a samsung sw80p washing machine
Need to find out what error code de means on a samsung sw80p washing machine
IFIXALL
  • 868 Answers
SOURCE: lg model wd8074fhb error code
you have a blocked pump,Remove the lower front panel ,remove the pump hoses and clean out pump/hoses.Please rate this , Thanx.
Posted on Jun 05, 2008
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
SOURCE: de error on my lg washing machine
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Posted on Oct 17, 2010
What does DE in red mean on a samsung DV400 washing machine
There is a door problem.
The following link may provide helpful information.
One can also search the internet using the following:
"DE error code, Samsung DV400"
Jun 02, 2017 | Samsung Washing Machines
What does the error code dE MEAN
you have not said what your washing machine you have.so this is for the samsung.
If the Machine is displaying "dE" error, kindly check for the following : First and foremost the door must be properly closed. You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact). Also, you can check the end of the drain hose is submerged in water.7 Mar 2014
'dE' Error is displayed on the panel of the Washing Machine? - Samsung
www.samsung.com/in/support/skp/faq/135992..if yours is not a samsung then please let me know.
Nov 20, 2016 | Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
Gives a error code DE Why is this
DE is door error on Samsung washer
means door is not locking
door lock or main PCB Door lock is the cheapest of the 2
Jul 02, 2015 | Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
What is DE error mean?
DE error code means "Door Error "indicates that the washing machine is not shutting ,locking or opening. Hope this helps you're problem.
Sep 11, 2011 | Washing Machines
My washing machine is flashing DE what does it mean
DE error code is indicative of a "Door Error".
Check this diagnostic procedure: DE lgknowledgebase
Hope helps.
Aug 13, 2011 | Washing Machines
My w/m have problem and the error code is the number DE.what is the problem??
DE error means door error wich means either the door lock or the main computer or the wiring in between.Sometimes all the parts above need to be replaced to repair this problem so beware it could get expensive to repair & i would honestly be thinking about replacing the samsung.
Feb 21, 2011 | Samsung Washing Machines
Washing Machines Logo
22 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
