Question about Alarm & Keyless Entry System Dodge Vehicles
How do i install an autopage rf225a, motion sensor, and siren on 2001 dodge ram?
    Habit-Forming:
    New Friend:
  • 186 Answers
Http://www.the12volt.com/installbay/forum_posts.asp?TID=52897 this site will help you for the wire location,
Posted on Apr 28, 2014
Does anyone have an installation manual for an Autopage RS-610 Plus? I need to program a new remote.
Note: This system can keep up to 4 remote transmitter in its memory. If
more than 4 transmitters programmed, the system will keep only the last
4 transmitters.
PROGRAMMING THE REMOTE TRANSMITTER
Enter:
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in the 'ON'
position. Within 15 seconds.
2. Push the Valet switch 2 times (Holding in on the 2nd push) until you
hear a long chirp. The transmitter is ready to program.
Program:
1. Press any button on transmitter until the siren responds with a
confirming chirp the first transmitter is now programmed.
2. Press button on the second transmitter until the siren responds with a
confirming chirp, the second transmitter is now programmed.
3. Apply the same procedure to program 3rd and 4th .
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. A 3 long
chirps & 3 parking light flashes to confirm exit.
Apr 12, 2017 | Autopage Vehicle Parts & Accessories
My front tire makes a loud whining/horn like sound when it is in motion, what can be the problem?
Either bad brakes on that side or a bad wheel bearing.
HOPE THAT HELPS
Dec 16, 2014 | 2014 Dodge Avenger
How do I adjust the timing on a 2001 Dodge Ram
There is no adjustment for the timing on a 2001 dodge ram 1500 4x4 5.2 liter . and the most likely cause on th eother problem is the abs speed sensor on the rear differential it is bolted to the top of the differential housing with a 10mm bolt remove it slowly in a twisting motion and put new differential grease on the o-ring slide it in and bolt it down and remeber to clear all codes or the sensor will run off of old paremeters
Sep 23, 2014 | 2001 Dodge Ram 1500 Truck 2WD
Engine code p1297 on 2001 dodge ram 1500 with 3.9
P1297 DODGE Description The Engine Control Module (ECM) detected no change in MAP sensor voltage.
- MAP Sensor harness is open or shorted
- MAP Sensor circuit poor electrical connection
- Faulty MAP Sensor
- Faulty ECM
Feb 27, 2013 | 2001 Dodge Ram 1500 Truck 2WD
Where is the coolant temp.sensor located on 2001 dodge 1500
The alternator needs to be removed to easily access and locate coolant temperature sensor.For more details and ECT diagram on 2001 dodge ram click the link below and follow the details to replace the coolant sensor:-----
http://technoanswers.blogspot.com/2012/10/dodge-coolant-temperature-sensor.html
These details will help.
Thanks.
Oct 21, 2012 | 1997 Dodge Ram 1500 Club Cab
Which type of siren that must be installed in Prisons, especially large prisons?
In the United States, there are several types of alarms that must all be installed before being certified by BOP.
Cameras, both regular, and 0 lux, or night vision type.
Claxon type sirens capable of producing 115 decibels loudness
Remote single cell door activation systems
Remote multi-cell door activation systems
Shatter sensors built into all the glass windows where an inmate might possibly be at.
New prisons are also installing strobometric flashers, so as to disorient the inmates in case of riot or other unrest in the facility.
All guards in the Prisons must carry handcuffs, and radios at all times while on duty, that way they can always call for help if need be.
Also, in many prisons, motion detection sensors are used so that even if there is no guard right there, the sensor will go off if an inmate manages to get into the wrong area.
I am sure there are other types as well, like heat sensors, and ground vibration sensors, so that it can pick up the vibration of walking across floors.
I hope this has helped you out .
Feb 22, 2011 | Global Industrial Alert Siren
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
I cant get the siren on my alarm to stop
turn ignition on, hold valet switch for 2 seconds.
May 21, 2010 | AutoPage RF425 LCD (RF425LCD RF425 LCD)...
2001 dodge ram 1500 5.9 camshaft position sensor location?
CAMSHAFT POSITION SENSOR 2001 Dodge Truck RAM 1500 1/2 ton 2WD 5.9L SFI 8cyl The Camshaft Position Sensor is located: Under hood, center, upper engine area, rear of intake manifold, mounted in distributor
If this is helpful.Please leave ositive Feedback. Thanks, SnugglePants
Oct 21, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Alarm & Keyless Entry System Dodge Vehicles Logo
76 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
