Question about Lands Phones
Siemens 7010 it will not switch on
The phone will not switch on do we need to replace battery in handset.... What's the correct button to press to switch phone on
  • Linda McMahon
    Linda McMahon Apr 12, 2014
    If we need to replace battery how do we open back of handset
    Problem Solver:
  • 19 Answers
Phone should turn on by itself. Have you left the phone in the base long enough for the battery to charge. It could take up to 24 hours. If you want to change the battery there is normally a section of the case on the bottom back of the handset that slides down to reveal the battery. Check the cost of the battery first, I have found that sometimes it is better to upgrade to a new phone due to the price of replacement batteries.
Posted on Apr 26, 2014
SOURCE: Handset lights up, but does not work, only beeps when you touch any key
first, hold down the "handset locator" button on the base, until the "charge" light flashes. then, hold down the flash/call waiting button until the LCD says "handset registering." if after about a minute it says "error!!!" then try again. that is what the instuctional booklet says. i have not done this successfully yet as i have the same problem, but this is apparently how you fix it.
Posted on Dec 22, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
Posted on Feb 10, 2008
SOURCE: PROBLEMS REPLACING ONE OF MY ADDITIONAL VT2420 HANDSETS
You need to de-register the broken handset then add (register) the new handset:
http://www.vtechphones.com/vtechui/support/dsp_product_faq.cfm?product_faqID=20854
Posted on May 19, 2008
RPaterson
  • 48 Answers
SOURCE: My phone is malfunctionning. The
If it's a cell phone, chances are it's your carrier that is at fault.
Posted on Jun 22, 2009
SOURCE: I am looking for a user guide for model 7010
Thank you for your reply, a daughter of mine solved my problem for me. So,I shall not be needing the User Guide after all.
Posted on Sep 02, 2009
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Uniden 5.8 cordless phone - replaced batteries, but now the phones don't ring....help?
up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Uniden Cordless Phone
Hi, I have a Siemens ( 4000 series) land line phone with an extra hand set. What steps do I need to take to have the second headset sync(?) to the same base so that both headsets are usable? I can not...
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones
Jan 17, 2011 | Lands Phones
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
Handset needs registration
I had the same problem and have seemed to figure it out. Take the handset near the base. Press the Prog/Mute button at the bottom of the phone. It will display a message to press the Pager on the base. The phone will then ask you for a Handset Name. Press the Prog/Mute button again and it will name the handset Handset 1.. it is working
Jul 31, 2008 | Uniden Cordless Phone
Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
