Question about HP PSC 1610 All-In-One InkJet Printer
Atasco de carro - HP PSC 1610 All-In-One InkJet Printer
3 Suggested Answers
  • 9 Answers
SOURCE: atolamento de papel
u can go service center.
Posted on Apr 05, 2010
mariolands
  • 2296 Answers
SOURCE: tengo una hp c6180 y
For this error this is the only thing you can try:
1. Without turning off the printer, disconnect the USB cable from the rear of the printer.
1. Remove the ink cartridges from the HP printer.
2. Wait for the 'Insert Cartridges ' message to display on the control panel.
3. Disconnect the power cord from the back of the product.
4. Wait 60 seconds.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
6. Reinsert the ink cartridges, and then close any open doors.
7. If you receive a prompt to print a calibration page, do so.
8. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Feb 04, 2011
How to change oil in sentra nissan 1996 model
Here are the steps of oil change in Nissan
1)Disconnect the cable from a battery from the negative battery terminal.
2)Eliminate the items on the oil box
3)Disconnect the gasket from the valve cover
4)Clean the chum surfaces of the valve cover and the engine head
5)Put the oil filler to the point of oil whole
6)Now add oil to this filler until it is full.
Jogos de carros Jogos de carros Jogos de carros grtis Jogos de Corrida de...
Feb 09, 2016 | 1996 Nissan Sentra
Tengo un multifuncional x2600 y me marca error atasco de papel, ojala me puedan ayudar...ya cambie los cartuchos ya trate de sacar una impresion y no me permite hacer nada..
Quite las hojas de papel desde el alimentador. Trate de abrir la tapa de la impresora y retire ambos cartuchos. Mientras que la cubierta está abierta, compruebe si hay obstrucciones en la ruta del carro del cartucho. Compruebe si hay conexiones sueltas. Si todo está bien en el área del cartucho, cierre la tapa. Desenchufe y vuelva a conectar la impresora a la fuente de energía para restablecerla. Cuando la impresora se enciende, vuelva a insertar un cartucho en primer lugar. Cierre la tapa y comprobar que no existen errores. Si no, abra la tapa de la impresora de nuevo y vuelva a insertar el cartucho de otros. Vuelva a colocar el cartucho lo que está causando el error que aparezca. Usted también puede tratar de insertar un cartucho de diferentes conocidos trabajando para determinar si el otro es culpable.
Nota: Esto se traduce con translate.google.com.
May 20, 2011 | Lexmark X2600 InkJet Printer
Tengo una hp c6180 y marca error 0xc05d0381 y no imprime luego dice atasco de carro ,
4. Wait 60 seconds.
Dec 01, 2010 | HP Photosmart C7180 All-In-One InkJet...
Mi impresora kodak esp5 marca atasco de papel y no tiene nada atascado ya lo cheque de antemano gracias
hola necesito k me ayude mi impresora kodak 3250 trabaja bien per de repente estab imprimiendo y se quedo atasco de papel la cheque y se lo saque apegue la compu y nada sol ome falta deschufar impresora el cable de alimentacion ke va laimpresora ala compu sera ke podra ayudarme eso o volves a instalar el disco del drive ayundeme por favor eske tengo un ciber y la ocupo. por favor
atte. Marylen se los agradeceria mucho. gracias
Nov 19, 2010 | Kodak ESP 5 Printer
Hey tengo problemas intalando mi radio jensen 9311, yo conecto todo bien pero el sonido no sale y cuando sale tiene mucha interferencia tu crees q me puedas ayudar gracias
le compraste el kit de alambre para conectar el radio con el carro, o lo conectaste de alambre a alambre. algunos carros necesitan el kit porque tienen amplificador de factory. agarra una vocina sola y conectala con el radio directamente sin ir por los alambres del carro y si se oye bien entonces el problema va ser con las conecsiones del carro. y si se oye igual entonces el radio tiene problemas.
Apr 01, 2010 | Car Audio & Video
Me prende un bonbillito en el tablero que es un carro con una llave adentro y el carro no prende
Es el sistema de seguridad ANTI THEFT SYSTEM, que desactiva la comunicacion con el COMPUTADOR para accesos no autorizados. Es probable que hayas desconectado la bateria recientemente o usado el PANICO de la alarma.
Sugiero revisar el manual de usuario del vehiculo, en el esta la forma de desactivarlo.
Suerte.
Mar 17, 2010 | 2006 Toyota Land Cruiser
Mi problema es q no tengo chispa pero si tengo pulsos de inyeccion y activacion de bomba de gasolina quisiera saber si es pastilla o bobina o sera la computadora?
Necesito saver que ano es el carro para poderte ayudar pero por lo general a esos carros se le va el modulo de control de la chispa si usa distrbuidor esta adentro pero eso varia de acuerdo con el año asi es que te aconsejo datos mas claros para ayudarte con una mejor repuesta
Jan 09, 2010 | Honda Civic Cars & Trucks
Carro ford focus pienso que la bomba de gasolina
CHECK FUEL PRESURE, FUEL CUTOFF SWITCH, FUSE, RELAY AND INJECTOR PLUSATION.
Nov 04, 2009 | 2003 Ford Focus
HP PSC 1610 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
