Question about Boating
I lost about 80% of power to the prop the engine seems to be running fine maybe a spun bearing in lower unit ????
  • 4 Answers
Sounds like you spun the hub in the prop try another prop and see if that fixes the problem
Posted on Apr 14, 2014
90 hp 2001 Mercury outboard runs with no power
Hey Robert,
This is not enough info for a decent diagnosis.. but here goes....Will the engine rev up cleanly and fast in neutral? Yes.. proceed - . No.. take it to a professional mechanic...
1. Does the no power mean it will not accelerate in the water? when in gear will the engine rev up and then still not go? ..YES-maybe a spun hub in prop.
2. Will the engine try to take off but not pull the boat and not rev when trying to take off? Take it to a professional mechanic for a compression check.
3. The spun hub is about the only thing you can fix if its not a serious engine issue!!
Jun 06, 2017 | Mercury Boating
Boat has issues on plane. Vibration and limit on speed. Prop is fine. Could this be an issue with gimbals?
Yes, it very well could be. If your propeller is good and it's hub bushing is not spun and your not picking up an air pocket then it's the gimbel or engine carrier bearing, which will melt and smoke. The gimbel bearing which is like a CV joint in a front wheel drive car. It will click on turns then go out all together. If it's not too late and you haven't tried it yet, pump some grease into it. Sometimes that helps if you catch it in time. The only other thing that will cause vibration and loss of speed is the gears in your unit. The only thing to do there is to check or drain the lower gear oil. You are probably right, it's the gimbel bearing.
Mar 25, 2017 | Boating
Cylender loaded with gas engine making knoking noise
Maybe a spun bearing or an oil pump not turning any more.
Jan 10, 2014 | 2002 Chrysler Sebring
Motor over revving
Firts thing I would look at is the hub in the propeller. It may be spun. Check that by removing it and looking at the back side for for burnt rubber or smell of burnt rubber. You can also (with the engine off and spark plug wires removed\ignition disabled) put the engine in forward gear and try and turn the prop counter clockwise. If the prop turns I would suspect the hub will need replaced. any prop rebuilding company can do this for around 50.00 or less. If the prop doesnt turn, You may need to loook into the lower unit internally and inspect the clutch\gears, etc.. Those can be suspect and usually due to shift cable issues, water intrusion, lack of oil changes etc.. Hope this helps.. Let me know if you need more assistance.
Dec 10, 2013 | Boating
My 8hp Mariner outboard has lost power. the engine runs fine but the prop is slipping. With the engine off and the gearshift in forward the prop can be spun by hand and makes a clicking noise. I did not...
The props have a rubber bushing in the hub that can start to slip after time.Take the prop off and take it to a prop shop,not a dealer, and they can check it for you.The bush is there to stop damage to the g/box and driveline if something is hit.All props can be spun if the engine is off and the motor is in gear.It's another driveline saver.But the prop can only be spun backwards and thats when it clicks.Hope this helps
Apr 15, 2010 | Boating
There is a clacking noise coming from the rear of the boat. It is a Chaparral with a 260hp Alpha drive. It started suddenly and seems to be getting worse each time we drive the boat. Engine runs good and...
With boat on trailer put drive in gear,engine off,remove bellow cover on the lower unit and check u-joint for any slack or noise when you try to rotate prop.Does clacking happen more when you raise lower unit?
Nov 15, 2009 | Boating
BOAT WONT MOVE WHEN IN REVERSE
how far below the boat is the propeller? Since the boat is fllat in back, you may need bigger proppeller. Check to make sure it is getting plenty of water flow
Jul 07, 2009 | Light Outboard Motor Boat Bass Fishing...
Prop not turning
if the prop spins out of the water but not in
it could just be a bad hub inside the prop
good luck with it
Jul 05, 2009 | Boating
60 hp Manier running great when losted all power ,motor runing
take your prop off and look at the hub you have a spun hub or the wrong size prop and it is cavitating or prop washing
Jun 28, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Aug 25, 2008 | Sport & Outdoor - Others
Boating Logo
53 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
