Question about Fisher and Paykel Dishwashers
Dv 601 codes
Unit starts ok but gets through part of cycle then red lights flash and beeps and unit stops.. not sure why this is
  • Fisher and P... Master
  • 3,247 Answers
It is very likely the flood switch trips part through the cycle. One cause is too much foaming due to incorrect detergent. The other is splashing of water from the drawer due to slightly leaky lid seal. Check out both these situations in particular if the red flashing only occurs temporarily and you are able to restart the dishwasher after sometime.
Posted on Apr 13, 2014
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
eagle338
  • 4889 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Posted on Feb 03, 2008
SOURCE: Whirlpool Dishwasher Model ADG 7560 Unit
found outlet pipe was kinked, stopping water flow
Posted on Sep 09, 2008
aborcass
  • 2651 Answers
SOURCE: clean light flashing and unit wont run
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Posted on Jan 24, 2009
livewire874
  • 618 Answers
SOURCE: Unit stopped will not turn
Check the power connections at connection box under kick plate . If ok then may be door switch(s)
Posted on Nov 18, 2010
Testimonial: "looks like the switch was busted.still not confirmed."
Cant get the controller for my fujitsu auy18asd to work with the unit theres no beeping or nothing
An easy way to check the remote is to use a digital camera. Turn the camera on and point the remote at the lens. Look at the camera screen and press a button on the remote. If it is working, you should see the transmitter flash a purple/blue colour. This is not visible with the naked eye so you have to use a digital camera to see it. A phone camera works fine. If you see the transmitter flashing, the remote is probably ok and the receiver board or controller board in the head unit is faulty.
Jun 29, 2014 | Fujitsu 18C1 Air Conditioner
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
PS3 wont work, red flashing light
If it flashes yellow to you have the Yellow light of death. google it. otherwise its just overheated
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
I have a Fisher and Paykel GWL11. When I start a cycle it stops
OK If you tell me which lights are flashing when it beeps I'll tell you the fault eg there are eight lights 00000000 1=on 0=Off cheers
May 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Clean light flashing
this is a safety failure of the unit not heating the water properly. if you push the " water heat, air dry, water heat, air dry" in that order, then it will go into the program mode and clear out that failure code.
then try the unit again, if you open the door during the heat cycle or it doesnt heat properly it will happen again. make sure you have hot enough water, 120 degrees, going to the unit and dont open the door after you start the cycle. if it continues call sears for service as it has a 1 year warranty.
Dec 09, 2008 | Kenmore 24 in. 15173 Stainless Steel...
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Washer flashing fault codes
truthfully, i think you have a malfunctioning board.if all parameters are correct and unit is washing while beeping is taking place. represents board.
May 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
