Question about LG WM2487H Front Load Washer
Lg intellowasher wf-t1081tp hot water intake slow
The hot water is only trickling in. Cold water has full water pressure. Checked and cleared out hose. Water pressure is fine UP TO the point it enters the machine. Is there a way to open the tops to see if there's a clog somewhere inside between the intake valve and the detergent dispenser area?
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Posted on Jul 11, 2007
particleman
  • 9 Answers
SOURCE: No hot water entering
1. Make sure water comes out of the hot water hose into a bucket.
2. Check to make sure the solenoid valve is working. The buzzing is the 60Hz on the coil and can make a lot of noise if valve does not operate properly. Try blowing into the hot water port. If the solenoid is functioning properly air will move freely, if not its stuck.
Posted on Jan 10, 2008
  • 489 Answers
SOURCE: LG WM-1285FHD Leaking from Dispenser Drawer area
There is a problem with the dispenser assembly where the drawer enters.  You will have to have it checked by a qualified LG technician to see what the problem is.
Posted on Apr 28, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
  • 105 Answers
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Posted on Aug 02, 2009
I have a LG Punch WF-C5856TC washing machine. Off late, Notice that the water is trickling in rather than flowing. Hence it takes really really long time to wash clothes. Pls advise
The first place to look is the inlet tap in the wall
even you have the tap on full the tap washer inside jams and prevents the full flow of the water
next check out the filter in the hose at the tap or at the washing machine end
next replace the water inlet solenoid
you can check this by changing the hose from the hot water tap onto the cold water tap and pressing the hot water button to fill
solenoids do not know the difference , they just work when the power is applied
Sep 08, 2015 | LG Washing Machines
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
What does "PE" error message
LG's 'PE' refers to '(water) Pressure Error'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 18, 2011 | LG WD-16115FD Front Load Washer
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Wld like to re-set temperature for washing to 'cold' Can't find manual. Wld like to know how to change settings. It is a 'LG Intellowasher 3.3 cu ft top loading 3 Step Turbodrum WF-T1081TP' Thank you
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Jan 04, 2009 | Washing Machines
Cold water only trickling into my washing machine
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
Sep 25, 2008 | Washing Machines
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
LG WM2487H Front Load Washer Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
