Question about Canon PIXMA MP600 all-In-One InkJet Printer
Does not print on paper
I have just un boxed my new Canon MP600 and set up as per the instructions. First job is the auto head align. This fails. It says AUTO HEAD ALIGN HAS FAILED. PRESS OK AND REPEAT OPERATION. .
6 times later and still no print. it goes through the motions but no ink on the paper.. Done a scan via the printer and again no ink on the paper but does everything else..
Rang canon and they think it could be the brand new print head or the genuine ink tanks!!!!
Any suggestions.
steve
Plymouth
  • 2 more comments
  • Anonymous Mar 19, 2014
    prints are not aligned, troubleshoot does not work
    prints are not printing up clear, words go into one another, brand new printer
  • Anonymous Mar 22, 2014
    I am setting up a brand new Canon MG1760 printer and keep getting an error message 2500 when I put the special paper in to auto align the print head...any ideas?
    just installed ink.. how to re align the head?
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
Daniel
Sydney
Posted on Nov 04, 2007
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Canon pixma mp600 print problem
Don waste your efforts & $, replace the print head is the best policy.
May 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
New cartridge check print head alignment
Generally speaking this is the procedure for most Canon printers. post your model # if these instructions don't work for you,
With the printer drivers installed you only need to carry out one further operation and that is the Print Head Alignment. Make sure you have some plain A4 (8 1/2 X 11) paper loaded then click on the Start button and select Printers and Faxes in the Settings. Right click the Canon printer icon and select Properties. On the Properties panel select the Maintenance tab and then click on the Print Head Alignment button. A pattern is printed, you must look carefully at each Column and decide which colour has the least lines i.e. the smoothest looking patch and enter the number (-3 to +7 ) in each of the eight boxes
Mar 22, 2009 | Canon Office Equipment & Supplies
I changed the ink in my canon ip1800 and now it the me the print head need alignment and i don't know how to do it.Can you help
1. For Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes
2. Select your printer model name icon.
-> Printers and Faxes.
3.Open the File menu and select Printing Preferences.
The printer driver setup window appears.
4.Click Print Head Alignment on the Maintenance tab.
A message appears.
5.Set the paper thickness lever to the left, and load a sheet of A4 or Letter size plain paper into the auto sheet feeder.
6.Follow the instruction in the message.
7.The Print Head Alignment dialog box opens.
Select the numbers of the patterns with the least amount of streaking in the associated boxes.
Clicking the patterns with the least amount of streaking in the preview window, will automatically set their numbers in the associated boxes.
8.When you have entered all the necessary values, click OK
And that should do the trick for you.
Sean
Feb 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
Canon PIXMA MP600 all-In-One InkJet Printer Logo
665 people viewed this question
old marine
old marine
