Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Control Lock light is on. Cannot get it off. cannot run washer
The control lock light is on and we cannot get it off in order to have the washing machine run. We tried unplugging, holding the cancel button for 3 seconds and holding the start button for 3 seconds. Does anyone know how to get the control lock off
  • neville sukul
    neville sukul Apr 02, 2014
    Hi, whoever u are, thank you so much. it worked. ns
  • 111 Answers
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Posted on Jun 18, 2009
  • mamas1128
    mamas1128 Aug 28, 2012
    WHERE IS THE END OF CYCLE SIGNAL
  • 82 Answers
To turn off the control lock, try pressing the control lock button for three seconds. and no, i am not joking.
  • TOMMY FERRELL
    TOMMY FERRELL Jan 24, 2016
    THAT DOESNT WORK I HAD TO PULL THE EMERGENCY LOCK LEVER... BUT WASHER STILL WONT WORK...
What should we do when control lock light is on and washer will not run
you'll need to call a repair professional and have the electronics controller assembly replaced.
Aug 12, 2014 | Frigidaire ATF6000ES Front Load Washer
Control lock light
control lock light ? have you got any blockages or dirty filters you may have to clean them.
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Control lock button is on and will not clear to wash clothes
Hi, Whirlpool makes their control lock very confusing. Often times, people will look on the control panel and the control lock light will go on and they can not figure out how to unlock the control panel. They will try pressing and holding the cancel button and unplugging the washer or dryer to reset it. None of these options work. All you need to do is press and hold the end of cycle button for 3 seconds and the control panel will unlock. If that doesn't unlock your controls, then unfortunately your interface control board is just shorted and will need to be ordered and replaced to fix the issue.
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
CONTROL LOCK LIGHT ON. CANN'T USE WASHER.
pull plug wait 5 minutes then plug back in go into diagnostics
close door
push control/on
select drain/spin
select no spin by pushing spin speed touch pad
push prewash optionj four timesw within 5 seconds
c:00 will light up
in order to advance to next step
push prewash option 2 times
if it does not enter diagnostics you must replace main control board
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on my front loader.
You should be able to unlock the control lock by holding the "end of cycle" signal for 3 seconds or until the "control locked" status light turns off.
If that doesn't work, please post your model number.
Mar 07, 2009 | Whirlpool GHW9400 Front Load Washer
How do you reset the control lock?
book said to hold the end of cycle signal button for three seconds or when the control locked light goes out, good luck
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off on duet
there is a button marked "control lock" hold for 3 secs and will release, its the far most right bottom button
Nov 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
1,101 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
