Advent torino x700 when i switch onscreen lights & cursor appearsnothing else happens
Normally internet icon shows i click on it & enter pin then start sceen shows
  • 3,320 Answers
What OS?
Posted on Apr 12, 2014
  • 136 Answers
SOURCE: Cannot access any programs on Toshiba Satellite A135-S4517
Either a tune up, or it has a faulty hard drive. If you can manage to get to My Computer, right click your C: drive, select Properties, go to the Tools tab and click Check For Errors. Check all the options, and start it. It will tell you that the tests can only proceed when you reboot. Check it in order to do so and reboot.
Good luck.
Posted on Nov 02, 2008
Geekman
  • 32281 Answers
SOURCE: My computer starts up perfectly fine, i click the " start windows normally" button, and it loads. Then after loading the screen turns black ( I can still see the LED light and cursor) PLEASE HELP!
When it ask you how you want to start the computer the select Last known Good Configuration. It should boot up normally.
Then go o the control Panel - System - Hardware - Device Manager and check for any devices that didn't install (the ones with the yellow ?)
You will need to reinstall these drivers.
Posted on Apr 19, 2009
  • 19 Answers
SOURCE: internet connection
Some laptops have a small switch on the body of the laptop that turns on/off the wireless connection, check for that first. Otherwise, it can be disabled with the function keys on the keyboard. Press and hold the 'fn' key and then press the key in the top row that has the little antenna icon, that should re-enable it.
Posted on Mar 03, 2009
ArcAiN6
  • 152 Answers
SOURCE: i can't see the picture
unplug the television, wait ten seconds, plug it back in. If that fails, try hitting 4 0's or 1234, or 4 1's... If that fails, you may need to press a special button on the remote to clear the password, for Toshiba's i believe it is the " recall " button, you must press it 4 times in 5 seconds to clear the password, and then you will be able to set a new pin
Posted on May 30, 2009
anjana03
  • 361 Answers
SOURCE: cursor moves, wont click!!
i think there may be two reason.1/some setting may be worang-go on conttrol panel and chose printer and other hardwere. inside click mouse and look setting.2/ your touchpad driver may not be working properly. stall it next.
Posted on Jun 12, 2009
How to connect the power led,power sw,hdd led on e-machine t2240
Apologizes your question hasn't received a solution until now. I have been 'away from my desk' for a while.
The eMachines T2240 desktop pc uses an Intel D845GVSR motherboard.
So let's go to Intel Support for more information, and to the specific product download page for the Intel D845GVSR motherboard,
Intel Desktop Board D845GVSR Product Guides
On this page left-click right on the blue title -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using has Adobe Reader on it which uses PDF files.
After you have downloaded the PDF file go to the top left and hover your mouse cursor on the rectangular icon. (To the left of the Up/Down arrows and Page: )
Hovering your mouse cursor over this icon will briefly reveal -
Toggle Sidebar. Click on this icon.
Now click on the icon to the immediate right of it. (Show Document Outline)
Scroll the Show Document Outline sidebar down until you see the heading - Connecting Internal Headers -
Now click on the heading immediately underneath it -
Connecting the- Front Panel Header -
[The front of your computer is the Front Panel. The area of connecting pins on the motherboard for the Front Panel is the Front Panel Header ]
On Page 11 in the Product Guide we see that S designates the Front Panel Header.
On Page 31 in the Product Guide it shows the Front Panel Header pinout. (The Front Panel Header is designated by C in the illustration)
Again on Page 32, it shows where the Front Panel cables connect to.
In case you are not able to view the Product Guide;
Viewing the motherboard installed in the computer case, the Front Panel Header lays parallel to the bottom of the motherboard, at the Bottom Right.
It is rectangular in shape and has 9 pins.
4 pins along the Top, and 5 pins along the Bottom.
The pins are numbered Even along the Top row;
Starting from the Left side of the Front Panel Header going to the right;
Pins 2, 4, 6,and 8. There is NO Pin 10.
The pins are numbered Odd along the Bottom row;
Starting from the Left going to the right;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the Harddrive Activity LED.
Pin 1 is for the Positive ( + ) wire. Pin 3 for the Ground wire.
In case the HDD LED is dim when the HarDDrive is active, switch the wires around. (Computer off and Anti-Static Precautions used)
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
Pin 5 is for the Ground wire.
C) Pin 9 is for 5 volt ( + ) power. Not Used.
(Usually the motherboard manufacturer uses this pin to test the motherboard)
D) Pins 2 and 4 are for the Power On LED.
-> Believe Pin 2 is for the Positive ( + ) wire.
If PWR LED is dim when computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
There is No Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 13, 2014 | E-Machines Computers & Internet
Advent torino x700 will not turn on when you power on should show network strenght and icon you then ckick on icon and enter pin number it then shows start page.when i power on screen lights grey and...
If this is a Windows 8 system, it sounds like you are having issues with the new 'hybrid shutdown' feature. I would suggest that you hold the power button for about 7 seconds at the cursor, this should turn off your PC. Then if you want to disable the hybrid shutdown, read the article in the link.
http://www.askvg.com/fix-windows-8-restart-and-shutdown-problems-by-disabling-hybrid-shutdown-feature/
Apr 12, 2014 | Computers & Internet
Lost logo for internet on my advent4221-b windows xp
Are you talking about the activity icon by the clock?
If so------control panel---network---go to our adapter and right click and click show icon when connected or something like that.
Apr 02, 2014 | Advent 4211c Notebook
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Motherboard power wiring
The eMachines W3653 (a?) uses an ECS 945GCT-M3 motherboard,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&MenuID=1&LanID=0
(Photo is J-U-N-K. Go to More pictures, and click on it.
{More pictures / Where to buy / Print}
Click on Download.
(Features / Specification / Download / Support / CPU / etc)
Click on MANUAL
(Driver / BIOS / MANUAL)
To the right of Download, click on the country NAME nearest yours.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country name, it may take up to 30 seconds, before the first page comes up. Took 5 seconds just now for me, using a medium speed DSL connection.
Hover your mouse cursor towards the Bottom/Middle.
The ghosted out navigation guide will appear.
Go to the far Right, and click on the Adobe Reader Toolbar icon.
(If you hover your mouse cursor over it, Show Adobe Reader toolbar, will briefly appear)
The Zoom Out icon at the top ( - ) decreases the view size.
The Zoom In icon at the top ( + ) increases the view size.
The Adobe Reader page number box is at the Top, and to the right of the Down Arrow.
The Adobe Reader page numbers, and the actual manual page numbers; do NOT match each other.
When I refer to a page it is for the Adobe Reader page number box.
You can use the Down Arrow to go page by page, to arrive at the page you want; or you can do this;
1) Left-click IN the Adobe Reader page number box.
Everything inside the box will be highlighted in Blue.
2) Type the page number you want.
3) Press the Enter key.
Go to Page 11. Increase the view size.
This is the Motherboard Layout.
Number 12 points to the Front Panel header.
(PANEL1)
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What you are asking for is the Front panel header pinout ]
Motherboard installed in computer; the Processor is to the Top, Ram Memory slots to the Right, white long PCI slots (2) to the Bottom;
The Front Panel header is at the BOTTOM/RIGHT corner.
Two rows of contact pins.
It is IN a long black rectangular strip, that also contains OTHER contact pins.
Starting on the LEFT side of this long black header, going towards the Right; you want the LAST 4 pins on the Top row. (There are 4 pins, then NO pin)
You want the LAST 5 pins on the Bottom row.
The Front Panel header pinout is on Page 33.
The Top row of pins are numbered EVEN.
The Bottom row of pins are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the Left side going towards the Right, Bottom row;
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
(LED = Light Emitting Diode)
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C.
Not Connected.
It is probably a 5 Volt test point for the factory to use.
D) Pins 2 and 4 are for the Power On LED. (Light)
If the PWR LED is dim when the computer is on, switch the wires around.
F) There is NO pin 10.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
Case hook up /power
http://global.aopen.com/products_download.aspx?sDropDownProd=52
i55HMt-HD / Manual / User's Manual / English / 12/15/2010
Click on small icon above 1127.6 KB
(Icon is a Floppy Disk drive with a Red arrow above it)
There is a small window that opens up.
Go to the bottom under the Mirror Sites heading.
To the right of the country nearest yours click on the blue ftp site.
I'm going to choose USA, San Jose, as an example.
I click on - ftp://ftp.aopen.com
After a few seconds the manual downloads. It is still in the small window. Go to the Maximize icon at the top right corner of the window, and click on it.
(Next to the Red X)
Now hover your mouse cursor down at the Bottom/Middle.
The ghosted out Navigation Guide will appear.
Go to the far right, and click on the Adobe Reader icon.
[When your mouse cursor is above it - Show Adobe Reader toolbar -
appears ]
Use the Plus ( + ) icon at the top of the file to increase the view size,
use the Minus ( - ) icon to decrease the view size.
Go to Page 14 - 2.7 Connecting Front Panel Cable
The motherboard is shown clocked 90 degrees to the right, from how it actually sits in the computer case.
Processor socket to the Top, Ram Memory slots to the Right, white long PCI slot to the bottom;
The Front Panel header is to the Top edge, and towards the right.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header ]
Situated in the computer case, the Front Panel header is along the top edge. It is parallel to the top edge, and is two rows of contact pins.
20 pins. 10 across the Top, 10 across the Bottom.
Pins across the Top row are numbered ODD.
Pins across the Bottom row are numbered EVEN.
Starting on the Right side on the Top row, and going towards the Left;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19
Starting on the Right side on the Bottom row, and going towards the Left;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
A) Pins 1 and 3 are N/C. Not Connected (White area)
B) Pins 7 and 9 are for the HarDDrive activity LED.
(Middle two pins in Orange area)
C) Pins 13, 15, 17, and 19 are for a Speaker. Internal speaker for the BIOS Beep Codes.
Pin 13 is for the Positive ( + ) wire
(Gray area)
D) Pins 2 and 4 are for a Reset switch, IF a Reset switch is used.
(Purple area)
E) Pins 12, 14, and 16 are for the Power On LED light.
Pins 12, 14, and 16 are used for a Power On LED light that has 3 wires. The LED has dual colors. (Green/Yellow?)
For a two wire Power On LED it is Pin 12, and Pin 14.
(Green area for all 3 pins)
F) Pins 18 and 20 are for the Power On switch.
(Pink or Red area)
Front USB headers are on Page 15.
Front Audio headers are on Page 16.
Regards,
joecoolvette
Sep 23, 2012 | AOpen MX46-533V (91.89U10.061) Motherboard
Where to plug the f_panel power cable
No I do not.
ECS Support does though,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=830&CategoryID=1&MenuID=16&LanID=0
Click on the Download tab.
(Features / Specification / Download / FAQ / CPU / Memory )
Click on Manual
(Driver / BIOS / Manual )
Scroll to the bottom, click ON the country name nearest yours.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
Go to the Bottom/Middle of the page with your mouse cursor. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it -
Show Adobe Reader toolbar - will briefly appear)
The Zoom In icon ( + ) increases the view size, if you click on it.
The Zoom Out icon ( - ) decreases the view size.
The PDF file page number box is to the right of the Down Arrow.
The PDF file page numbers, and the motherboard manual page numbers, do Not match.
When I refer to a page it is the PDF file page.
If you know the page number you want, you can go page by page, using the Down Arrow to arrive at it,
Or;
1) Put your mouse cursor in the PDF file page number box,
left-click once. (Anything in the box is now highlighted in blue)
Go to Page 10. Motherboard Components.
Motherboard installed in your computer;
Processor to the Top, Ram Memory slots to the Right, and white PCI slots to the Bottom;
The Front Panel header is at the Bottom/Right corner. (8)
Go to Page 33. Front Panel header pinout.
The Front Panel header lies horizontal, and parallel to the bottom edge of the motherboard.
It is two rows of contact pins.
The TOP row is numbered EVEN.
The Bottom row is numbered ODD.
Starting from the LEFT side going towards the Right, for the Top row:
Starting from the LEFT side going towards the Right, for the Bottom row;
A) Pins 1 and 3 are for the HarDDrive activity LED light.
If the HDD LED is dim when the harddrive is active, switch the two wires around.
C) Pin 9 is N/C. Not Connected. It was for factory use.
D) Pins 2 and 4 are for the Power On LED light.
If the Power On LED is dim when the computer is on, switch the wires around.
Regards,
joecoolvette
Jul 22, 2012 | EliteGroup Computers & Internet
Hi i had a wireless internet connection on my advent laptop till about 2 weeks ago and it doesn,t work anymore i have a internet conection as i,m using a different one and work perfect but this one...
Hi Friend, In this case as you have told me that you have other laptop which is working fine wirelesly. I would like you to check the IP address of the system in which you are facing the issues.
To check the IP address: 1) If system has XP Click on "Start" and then "Run". Type "cmd" in Run and hit enter A black screen will pop up, in that type "ipconfig", where the cursor will be blinking Check the IP adress under " Ethernet adapter local area connection" & " Wireless adapter"
2) If it is Vista/Win 7 Click on Start again and in Search field type cmd and hit enter Same black screen will pop up and repeat the same above steps in the black window and check the IP adress
Dec 07, 2010 | Computers & Internet
Forgot Bios Password Have Pw Icon onscreen
To nreset password in Bios on Toshiba units.
Open RAM door on rear. Locate pins some models these p[ins are between the ram modueles. Ensure the set is off and bridge the two pins ( looks like a littel plug with needle type pins with a paper clip or screwdriver. Replace the door and reboot Enter a new passowrd if needed.
Thanks for using FIXYA
Apr 13, 2010 | Toshiba Satellite Pro A210-EZ2203X...
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
Computers & Internet Logo
David Payne
David Payne
