Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My Hayward H400 will not turn on
I will start my pool filter and the heater will not turn on.
  • 372 Answers
Does the heater sound like it is trying to fire? (Fan on, clicking sound). Check your filter pressure. If it is high, it may be causing the heater not to fire because the heater doesn't know the pump is running.
Posted on Apr 13, 2014
  • 11 Answers
SOURCE: Hayward H400 heater problem
LO usually indicates low water pressure. Check the pressure in your filter. You may need to backwash. If the filter is to clogged then the water pressure in the heater is so low that it won't activate the pressure switch. While checking the pressure turn the pump off and then on to make sure the pressure gauge is actually working. Also check the pressure coming out of the inlets into the pool. You should be able to tell if you have sufficient water pressure.
Posted on Jan 28, 2009
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
  • 128 Answers
SOURCE: same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Posted on Aug 23, 2009
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
Your pool chemistry is likely out of balance and leaving a residue on your heat exchanger coils. Had the same exact problem. Called a technician out and he said that I needed a new Heater after talking to Hayward. No warranty situation for sure. I went to the pool store, got 2 pieces of hose and hooked it up through my pump. Put a coil cleaner mixed with industrial vinigar and ran it for two days and all is good now. Solution after that was simply good chemistry in the pool. Salt water pool by the way.
Posted on Sep 20, 2012
Lo showing on display won't start
you have an open safety circuit. usually the pressure switch. clean out pump basket, back wash filter to start. you may have a faulty pressure switch
May 02, 2014 | Hayward H-series Electronic Gas Pool...
Error code
make sure water filter is CLEAN ! this will throw a code
Jun 22, 2013 | Hayward H-series Electronic Gas Pool...
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
I can not turn off ob on the screen of my Hayward pool heater
I looked up the owners manual for the Hayward H400 heater and it did not list the "ob" indication. For this reason I would call the and they likely can help you out.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Hayward H-series Electronic Gas Pool...
Hi I hay a Hayward H400 pool heater. It is 2
This is a water flow problem and will be the by-pass assembly in the water manifold. Or their may be an external by-pass wich will be a valve bridging the inlet and outlet pipes for the water. This valve if you have it should be 80-90% closed to force water through heater. Before you do anything be sure to check to be sure the filter and baskets are clean. Often this is the problem.
Apr 25, 2010 | Pool & Spa
Hauward H400 heater won't turn on
check pressure switch operation most heaters will not operate without sufficient water flow/pressure. You can use a multimeter to troubleshoot the wiring using the schematic. If its induced draft milivolt ignition verify there is suffiecient gas flow to the unit
May 25, 2009 | Hayward H - Series 400 Heater Top for In -...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
174 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
