Question about Denon AVR-3200 Receiver
O the denon avr 3200 how do you switch from analog to digital
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
fredw988
SOURCE: DENON AVR-3200
I recently downloaded a PDF file from Denon. Just go to the archive files and search for the model of Denon receiver you have and select download file.
Posted on Oct 24, 2008
marketex
  • 371 Answers
SOURCE: Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Posted on Apr 11, 2009
SOURCE: Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Posted on Apr 29, 2009
  • 1039 Answers
SOURCE: I need a users manual for a denon avr-3200.could
Go to Dennon website and you should be able to download the manual.
Posted on Nov 21, 2009
I have an Denon AVR-589 and it is showing (analog) but I need to change it to Digital and do not know how.
RTFM. Your external digital sources are responsible for delivering the digital content. They probably have manuals, too.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
Apr 22, 2011 | Denon AVR-589 Receiver
In cable / sat mode accidentally switched to analog in stereo. i have 5 surround sound and can not get any sound. how do i get out of analog and stereo - i have a denon avr 1911
Carefully examine the front panel indicators for status of switches you DON'T want active.
http://www.retrevo.com/support/Denon-AVR-1911-Receivers-manual/id/23695ci376/t/2/
Register and download it for free at retrevo.com
See Page 17 and consider how the digital audio is assigned (page 46).
Feb 13, 2011 | Denon AVR-1911 Receiver
I have an avr 3200 can it use 2 coaxial inputs and how good is the sound quality compared to newer avrs
Denon being one of the best names in the biz and this being an upper-crust modfel, I'd say anyone without a 'golden-ear' would be hard pressed to t\distinguish its sound from any other amplifier in existence.
The Denon site doesn't list and AVR-3200, but the AVR-3300 has 1 coaxial digital audio and 3 optical digital audio inputs.
If you're looking to run multiple coaxial devices and there aren't enough inputs this is what I do...
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Jan 15, 2011 | Denon AVR-3200 Receiver
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
Ext. input]
Apr 11, 2009 | Denon AVR-1403 Receiver
Denon AVR 886 only shows analog input
Are your speakers able to handle the 886's power. I have the same reciever and changed by speakers as the Denon would turn off instead of frying the speakers.
As for the digital, have you used the option to change your audio feed and video feed. (for example - I'll show photos through the front input but use the CD -digital for music. Maybe the audio feed is locked onto an analog input. Just a suggestion.
Jan 01, 2009 | Denon AVR-886 Receiver
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
DENON AVR-3801 Digital problems
Check with DVD Player settings.
Jul 20, 2008 | Denon AVR-3801 Receiver
NO SUB OUTPUT
go into the settings and set ALL speakers to SMALL even if they're big and leave them that way.
Then, in the screen, say YES to sub.
Nov 13, 2007 | Denon AVR-3200 Receiver
57 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
