Question about Kocaso MID M9100 9 Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Multi-Touch 8GB 512RAM Tablet PC-Purple
Error messages keep getting unfortunately, email stopped or launcher stopped can't clear
  •  Mike M
    Mike M Apr 13, 2014
    Hi Brenda Henderson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
The launcher has stopped
go to launcher, stop it and clear data and cache. Exit the settings menu and restart.
http://forums.androidcentral.com/asus-memo-pad-hd7/357082-unfortunately-launcher-has-stopped.html
Jul 07, 2016 | Tablets & eReaders
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Jan 01, 2016 | Polaroid Tablets & eReaders
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
Dec 12, 2015 | Tablets & eReaders
I have a azpen A720 tablet and I am getting a message that says unfortunately, launcher has stopped. How can I fix this?
Press ok. The error should go away. If it doesn't reload correctly you should backup and reload tablet O/S
Mar 01, 2015 | Tablets & eReaders
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Mar 17, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Received message: Unfortunatly launcher has stopped
You could try the free GO Launcher HD for Android at the Google Play store, (just Google "Asus tablet launcher"), but I find that if I restart the tablet when it says "launcher has stopped" or even just switch to another screen it carries on anyway, so it's hardly worthwhile installing another launcher for an occasional annoyance (so far anyway, fingers crossed).
Dec 18, 2013 | ASUS Tablets & eReaders
Error message
Here is a web site with a number of solutions to try and fix the error you are seeing:
HOW TO Fix process com google process gapps has stopped Error Message...
Jul 10, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
A13 tablet launcher not working due to density
I just did something exactly like this on my phone. Here's what I did for solving it.
NOTE: you will need access to a PC with internet connection and your problem Device must have access to the internet. You also need access to the PLAY store on both the PC and the problem device. From what I understand from reading your explanation this should not be a problem.
1 - Start your Device as normal and when you get the force close message go to the Report option.2 - Once on the report screen (accept the terms and conditions if they appear) you should be able to pull down the notifications bar.3. On the PC go to the play store (you must log in with the same account as the one in your problem device)4. Search for a different Launcher and install it through the play store on your PC. (I used Zeam Launcher for resolving my issue but I did this on a phone so it might not be available for a tablet. You can search for Launcher and find one that way)
5. The new launcher should automatically start downloading and installing on your problem device. You should be able to see this happening on the notification bar.
6. Once finished, just go back to the main screen. You should get the option of what launcher to use. Select the newly installed launcher. (do no use the default option).
7. Once in the new launcher, go to the density changer application and change it back to the original density.
8. Reboot your tablet and it should now work correctly.
NOTE #2: I did this on a phone. I've never owned a tablet so I'm not 100% sure this will work for you.
Hope this helps solve your problem.
Jan 01, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
My daughter's new Childpad is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to reconnect to wireless router but no joy. What can I do?
Look. It happened to me and drove me crazy. I was about to brick my new mobile phone. In my case it was the "Moon call log" icon on the home screen. Believe it or not when I remove the icon the error message no more appears when I restart the mobile phone. Then again when I place it (the icon on home screen) the annoying error message "Unfortunately, Launcher has stopped" will comeback again. In your case it could be any icon or widget.
I solved the problem by uninstalling the application and installing it back from Play Store unlike what I did before by installing it from the .apk file.
Regards,
Oct 28, 2012 | Archos 4GB Child Pad 7" Android 4.0 Tablet...
Kocaso MID M9100 9 Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Multi-Touch 8GB 512RAM Tablet PC-Purple Logo
21 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
