Question about Hardware & Accessories
PR OFF My sprinkler system was working when I first turned it on, but I unpluged it and turned the water off. The very next day I went to turn it back on to program, and all I get on my control panel is PR OFF I did replace fuse and battery and pluged it in but now when I turn the nob on anything '' days to water, custom schedule watering time, watering start time, and current time and day'' it only displays PR OFF. system is a ESP-6Si.
    President:
  • 1,723 Answers
On the inside open up the second door and on the back there is a small reset button, push it and it should reset and be ready for new program.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
Toro lawn sprinkler system, shut water off went to winterize system hooked compressor to blow out plug turned on first zone, water blew out everything good, went to blow out 4 other zones and nothing
I may suggest your distributor was set to the first zone.
Therefore, neither water nor compressed air will "flow" in any zone except that one.
See if turning on the electric and setting a different zone will accomplish your desired result.
God bless your efforts.
Nov 11, 2016 | Garden
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
Charged my RD 600 system and water comes out of all 5 stations
Make sure the bleeders are closed. Sounds like all the valves are open and all are running at the same time.
Apr 11, 2014 | Irritrol RD600-INT-R Rain Dial 6 Station...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
I have misplaced my manual for the 24-hour timer, and I want to make sure I am using the "tripper" clips appropriately: do I place one in each slot that I want the sprinkler zone to run--and...
This device is simply a 24 hour timer. It has a special enclosure classified as "Rain Tight" that helps prevent rain from entering - as water from a hose directed at it would enter the enclosure causing damage to the timer.
It is NOT a timer designed to operate a traditional pop-up sprinkler system. Those timing devices allow water to flow into the lawn sprinkler system and spray out from a certain area of sprinklers for a predetermined amount of time, then switches this area or zone off and turns on the next. This continues until all zones have watered the area where sprinklers have been installed.
The device you are asking about simply switches power on and off to one load. It can not control multiple loads - or as in your case "zones". You would install ON trippers at the time of day on the yellow time disc when the load would be ON and install OFF tripper when the load should be turned OFF. If the load were a light, you could turn this light on and off many times a day - dependent only on how many ON and OFF trippers you installed on the yellow time disc.
A sprinkler timer must be selected instead. This will allow you to select the number of days between watering, will operate many zones, control of how long the water is to remain on to each zone, detect if it has recently rained or if it is currently raining, etc. One is pictured below:
I hope this helps. If you have additional questions or comments, please provide the manufacturer's name AND the exact model number of the timer you are talking about. Good luck. Please rate my reply. Thank you.
Apr 13, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
of NO watering. The skipper wheel must have all pins UP for daily
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
Nov 24, 2010 | Intermatic R8816P101C -...
Sprinkler System reads PR OFF
You need to reprogram your timer, as whenever you change the batteries, several maker's timers lose the program you've put into them. The PR OFF means the Program is turned OFF and you must re-enter the start and stop times and day(s) you wish to have the sprinkler system runnning.
Hope you find this Very Helpful and best regards.
Aug 24, 2009 | Hardware & Accessories
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Hardware & Accessories Logo
594 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
