Question about True Fitness TRUE ES900 Treadmill
Es900 stride motor 1 error - True Fitness TRUE ES900 Treadmill
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Winshed wipers does not retrun. intermittent does not work & rewiper not working
blow fuse.
the wiper motor auto returns.
if not , you lost power, (fuse)
if it has power, and the wipe hangs mid stride.
1: linkage jammed.
2: motor gear box switch bad.
Sep 26, 2013 | 1999 Honda Passport
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
Can you use hi 8 tape in the ES900 Analog Camcorder
I believe this camcorder is 8mm only, so you won't be able to use a Hi8 tape with it. They will not play right in your camcorder.
Sep 19, 2010 | Canon ES900 Camcorder
Convert my canon es900 video to dvd
If you have a video card that has a video in port, plug in your 8mm camcorder and capture the movie. Depending on the quality you save it as determines the size of the file.
This is the simplest way in leiu of paying to have it done or "projecting" the image onto another media physically.
There are machines designed to do this of course but they're not cheap. If you know someone with a Digital8 camcorder. Sony D8 backward support V8 and Hi8, so you can just simply insert the V8/Hi8 tapes into the D8 camcorder, then transer them to computer in DV format through firewire cable.
Let me know if this helped
Dec 22, 2008 | Canon ES900 Camcorder
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
Self-eject
Hi there, I think I can offer some info, though it's not good news.
This cassette ejection is controled by a small motor in the bottom of the cassette carriage (see picture). Unfortunatly whether the problem be this cheap little motor or a switch that controls it, taking it to a repair shop would cost much more than this little camcorder is worth.8477600.jpg Sorry for the bad news, I have the same camera as you can see it's taken apart now. I posted another solution to get the tape out if you come to that problem.
Hope this helps
Jan 19, 2007 | Canon ES900 Camcorder
True Fitness TRUE ES900 Treadmill Logo
83 people viewed this question
Top True Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a True Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
