Question about Epson Perfection 4490 Film / Flatbed Scanner
Replace lamp Need to replace lamp
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
I have a 50" Sony Wega, the lamp has blown out, I have the lamp and now need to replace the lamp,, I have turned the TV around and I'm facing hit head on,, How do I replace the lamp..? Do I need to remove...
Look in the user manual on lamp replacement. Usually a door held by one screw on right side (when facing front of TV), or behind lower front panel IF removable.
Apr 13, 2010 | Sony KDF50E2010ATNS 50" HDTV-Ready LCD TV
Why does it say replace lamp
Have you replaced the lamp? If so did you reset the lamp timer?
If no to number 1 then you need to replace the lamp they are only good for 1000-1500 hrs then need to be replaced before the blow out all together.
Feb 17, 2010 | Sony VPL-ES4 Projector
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
When I turn on the TV, nothing comes on. No pictures or sound. Red light comes on where it says lamp. Do I need to replace the lamp. Please kinldy advise . Ty
Yes. You need to replace the lamp. Mine did this when my lamp burned out.
You can try pressing <menu> and <device> at the same time, and you'll get a code flashed out to you (tens digit followed by unit digit). You'll likely see one of the following codes:
  • 34 Lamp abnormality
  • 36 Lamp Ballast or exhaust fan failed.
  • 38 Lamp temperature too high
  • 42 Lamp Fan Failed
But the user's manual and the repair manual both say that a red lamp light means your lamp isn't working (most likely it needs to be replaced).
May 10, 2009 | Mitsubishi WD62627 62" HDTV
Need to replaced lamp
The easy way to confirm if it is the bulb. Unplug the power to the TV. Remove 2 screws that keeps the lamp cover in the TV. (see manual on lamp replacement). This is on the left side of the TV. Then remove the 2 screws that hold the lamp unit in. Pull out the lamp unit by the handle and then look at the lamp. If it is broken, you will need to replace the lamp.
Dec 03, 2008 | Hitachi 50VF820 Projection TV
Sony 42'' kdf42we655 no picture , lamp light flashing
If the lamp light is flashing, yes you need a new lamp. Be sure to buy an original Sony lamp as the replacement lamps are garbage and are not worth the discount. Please rate this solution. Thanks!
Nov 15, 2008 | Sony KDF-42WE655 Television
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Epson Perfection 4490 Film / Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
