Question about LG LHB335 1100W Network Bray Disc Home Theater System
Lg lhb335 power light blinks but wont turn on
Receiver stopped working along with a lot of other equipment afterpower surge from a thunderstorm
  • Tanis Hackmeyer
    Tanis Hackmeyer Apr 14, 2014
    Follow up post: the power light does not blink; it remains lit (solid red light) but nothing happens at all with the system - it doesn't turn on or make any sound as if it is trying to turn on. Could it be a fuse, capacitor or power cord issue since it happened after storm? LG offered no solution and I cannot find any new replacements of this product.
  • 267 Answers
SOURCE: Power problem with an LG 50PC3D Plasma 50" TV
YOU PROBALY HAVE A BAD Y SUSTAIN BOARD OR POWER SUPPLY. POWER NEEDS TO BE DISCONNECTED FROM THE Y SUSTAIN AND THE VA & VS VOLTAGES CHECKED.
Posted on Jul 27, 2009
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
freetek
  • 5568 Answers
SOURCE: No indicator light or power
Please look at these two links; I suspect your problem is related:
http://www.fixya.com/support/t4592070-tv_no_power_will_not_switch
http://www.fixya.com/support/t4596948-tv_stopped_working_bit_fizzing
This model seems to be having a ton of power supply problems.
Posted on Apr 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: LG LHB335 player will not
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 05, 2011
archaeology
  • 662 Answers
SOURCE: we had a thunderstorm with
As an electrician, when someone loses more than 1 item of electronics in a day, its almost
always traceable to a nearby lightning strike, accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
The converter box may be replaced by DirecTV, you'd have to contact their customer
service at http://www.directv.com/DTVAPP/content/customerservice
If desperate, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Posted on Aug 17, 2011
Testimonial: "thanks a mil! appreciate the reply. and the future advice as to how to prevent from happening again - i will take it. "
LG 60PN6500 plasma tv power surged. has no picture and i think no sound. tv wont turn on but stand by light illuminates but then shuts off. in a cycle fashion. cant find my multi-meter to check fuses
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2017 | LG Televison & Video
42 inch flat screen sanyo wont power on wont do nothing bought 2 years ago
Power surges, such as those caused during lightning storms, can often cause power supplies in electronics to fail. Sometimes, if you're lucky, the manufacturer will have placed a protection fuse in the power supply which can be replaced after a surge. If there is no such fuse, the power supply typically will need to be replaced for the equipment to regain function.
It is VERY IMPORTANT to use SURGE PROTECTORS on all electronics, especially if you live in an area where thunderstorms are commonplace. This will protect your electronics from most (not all) surges that would otherwise zap them into failure.
May 24, 2014 | Televison & Video
Why wont my 42" vizio razor led hdtv turn on?
The TV's power supply has certainly got affected. Most probably some of the ground tracks might have got burnt along with a few components and this might require attention by a qualified service technician.
Jul 13, 2012 | LG 42LC2D 42 in. LCD HDTV
LG LHB335 player will not power on. Light stays red, no flashing or anything. Will not power on at all. tried unplugging and holding button for 30 seconds, and nothing. It was working fine one minute,...
Mar 05, 2011 | LG LHB335 Theater System
I have an LG 42lg50 TV that was working fine earlier today, While I was out of the house an Thunderstorm came up and power failed at least twice. I come back home to find my TV not working properly. The...
An electrical pulse from the thunderstorm has affected your TV. (Was it on a surge protector?)
There is a small possibility that it will come back.
Unplug the television and let it sit for an hour or more and then re-plug it.
If you need to get a new TV, also get a good surge protector such as Panamax.
Jun 14, 2010 | LG 42LG50 42 in. LCD HDTV
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
Blinking Standby Light on receiver, no power
Unplug from power socket for few hours,most likely had a surge from storm and destroyed,either way will need to be serviced to evaluate damage if power trick does not work
Jan 05, 2009 | Pioneer VSX-915-K 7.1 Channels Receiver
Jul 29, 2008 | LG 50PX4DR 50 in. Plasma TV
52" LG DLP
you may have had a power surge
Jun 17, 2008 | LG RU-52SZ30 52" Rear Projection...
LG LHB335 1100W Network Bray Disc Home Theater System Logo
35 people viewed this question
Computer Repairing
Computer Repairing
