Electrolux evf 10240 do not heating. Everything else is OK. New heater is in machine. What is the problem?
    Problem Solver:
  • 8 Answers
Over temperature safety thermostat maybe open circuit if fitted temperature control thermostat or thermistor faulty ,water level sensor tube blocked so circuit does not switch on without water level correct. Lastly broken wire somewhere
Posted on Apr 13, 2014
Lg tromm electric heater has no heat
check ur heater element, the hi limit and the thermal cut off fuse.
Aug 27, 2014 | LG Tromm Electric Dryer
Oven overheating
try check sensor thermo..maybe its bad..replace new one.cause its cant control heater.
Jan 29, 2014 | Electrolux Ovens
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
Electrolux dishwasher not heating water
If your Ohms are at "0" then the heater is open.
Jul 31, 2012 | Electrolux Dishwashers
The washing machine trips the circuit board every time it is on...is this the heating element, drum or other?. easier to fix or get new one?
Check with the different programmes, to make sure when the tripping comes into force. If during the heat wash , then possible shorting in heater but if random please ceck the motor capacitor and change it . I dont think the issue is very much if the machine is running at other times, but if this trips on switch off , it can be easily identified byt a circuit check with a multimeter. maybe motor , capacitor, surge protector. Check this out, Helpful?
Aug 20, 2010 | Electrolux Washing Machines
Electrolux ewx14440w starts but then turns off no codes show last time it was the heating element
check the motor or heater is not down to earth. you need 500v insulation tester for this.
Jul 20, 2010 | Electrolux Washing Machines
Shorting out and Leaking
Just looking at that model on the Electrolux site and the wash pump would cost $167.73,and the manifold pipe would be about $25.I dont know what they mean by feeder pipe.but you have the hose to the machine cost $34.60 or the hose down by the pump which would cost $20.50.I would be inclined to get a second opinion or source the parts yourself.The fault on these machines normally was that the rigid plastic water feed manifold pipe would tend to split on the thread just inside the corner of the unit and water would run down onto the heater and the pump.Normally after replacing the pipe and drying out the electrics the machine would be ok again.
Hope this helps.
Jul 07, 2010 | Electrolux Dishwashers
My electrolux eod33002 bottom oven does not heat up but light and fan work. The top oven works OK
If youhave a ELECTROLUX electric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fan motor in theback of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from our websitethese can be tested with a electric meter.
To gain access to the ELECTROLUX element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if you look closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is opencircuit i.e. broken inside the element casing, either way it will needreplacing. Some elements will are fixed from inside the oven and some are heldin place by nuts from the rear of the machine.
2, If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
4, A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 04, 2010 | Electrolux Ovens
Electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
Jan 02, 2010 | Electrolux Dryers
Washing Machines Logo
Top Washing Machines Experts
