Question about Sony Televison & Video
Horizontal lines across tv
I have a series of horizontal lines throughout the tv screen. Numerous lines approximately 6 inches long. Problem is getting worse as time goes on.
  • Sony Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 12, 2014
Pink/Blue horizontal line on TV
Considering it is a 32 inch set and costs now under 300 dollars it may or may not be worth fixing.
To give an educated guess: either whatever it uses for an inverter board may be bad or damaged OR even the main board that processes all signal into or out to the screen may have either a bad connection(unlikely but possible) or be causing this.
A fatal issue could be something wrong in the screen unit (panel) itself.
I gather set is not under any warranty at this time.
Apr 05, 2012 | Televison & Video
I have a KDL 46XBR5 which displays horizontal lines across the screen for approximately 5 minutes after turning on the TV. Is there a fix for this problem?
The reddish blotchy screen also had a series of horizontal lines/sections of screen on occasion. I was able to determine that the ground wire screws were loose (loosened and retightend all of them) and a few of the connections between boards (the wires/plugs) were loose. Seems to have resolved the issue without having to replace any boards/caps etc. I would try this free 20 minute fix before searching out a new board.
Jul 28, 2010 | Sony KDL-46XBR5 46 in. LCD HDTV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
We have a Sony Triniton 32 inch TV we bought approximately in 2000. For a couple of weeks we had horizontal lines across the screen, then it just went black, no audio, nothing. Just comes on and off....
It is probably you horizontal output or horizontal output drivers. The newer TVs derive all there power from the horizontal circuit. This can only be fixed by an experienced technician as that area produces in excess of 20,000 volts to light the screen. Don't try to fix it your self as you could cause more damage or be electrocuted.
Oct 07, 2009 | Televison & Video
HORIZONTAL LINE THROUGH PICTURE
Defective LCD panel. I hope it is under warranty, otherwise you'll have to live with it or buy a new set, as the LCD panel costs almost as much as the TV itself.
May 20, 2009 | Sharp Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Televison & Video Logo
339 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
