Question about Motorola Mobility H700 Wireless Headset
The pairing light won't stay
Iam having the same problem, every time i open the boom the pairing light will come on only for 3 to 4 seconds. None of my bluetooth devices can pick up the signal.... can anyone help
  • 55 Answers
Open the boom of the reciever right after the light turns purple... if you do it fast enough it will stay lit.
Posted on Jun 29, 2009
Orb headset ps3 will not pair with ps3
have you put the motorla headset in pairing mode?
hold down the middle button for 6 seconds till the light stays solid, then open the boom mic and the light should remain solid indicating the headset is in pairing mode
Sep 28, 2009 | Motorola Mobility H710 Bluetooth Headset
HS 850 handset is not getting charged
The light is supposed to go off when fully charged.
With the boom closed, press & hold the main button until the blue light comes on (about 3 seconds) then release the button & open the boom. The light stays on, and the bluetooth is now in "pairing" mode. Search for it with your phone. The password is 0000 (zeros).
Jun 09, 2009 | Motorola Mobility HS850 Consumer Headset
Blue light will not stay lit
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
My Motorola h700 bluetooth will not pair
Rest assured that the drop did not cause this.  There is a general problem with these H700's.
Press the multifunction button until the led turns purple.  Keep it pressed in while you flip the arm open.  The arm needs to be kept fully extended to keep it in pairing mode.  If you succeed in positioning the arm correctly, a steady blue light will be on.  If the light goes off...close the arm and try again.
While in this mode...execute the pairing procedure from your phone...it should find the H700.  The default key is "0000".
Oct 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Sep 16, 2007 | Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Trying to pair Motorola HS850 to cell but I hold down button and light comes on but won't stay on
you hold the button with the boom closed and as soon as the light stops blinking you realease the button and open the boom, the light should remain on and steady. promt your cell phone to find it and the code is 0000
Mar 25, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H700 Wireless Headset Logo
861 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
