Question about Radio Shack Radio Communications
Radio works but can transmit and only hear ocassional traffic
When radio is switched on I only hear background noise
    Genius:
  • Radio Shack Master
  • 1,795 Answers
Thats happening a lot today.I don't think its your radio ,I think its just background noise because there is no one on the radio but you at the time .There is so much skip working all the channels that it creates a sssshhhhh noise in the radio and it gets real loud at times. some times going over an s 9 and if that is the case you won't be able to hear or talk on the radio .
Posted on Feb 23, 2015
2 Suggested Answers
  • 1274 Answers
SOURCE: cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
Posted on May 29, 2010
IS there a way to check if my walkie talkie antenna is borken
The antennas break, most often internally at the solder joint on the main board. There really is not test other than it works poorly. You could wiggle it when transmitting and if you hear static, popping or other noise, stop transmitting at once! Transmitting without a working antenna can damage a radio. The repair is to take it apart and resolder.
Mar 04, 2016 | Motorola Talkabout Mr350r 2 Way Radio
Cobra 19 classic
I would open up the radio and look for burnt traces, primarily by the output transistor and near where the power comes in. If you have another radio near by (within several feet) and it transmits on the same channel that your radio is on, can you hear it?? If you transmit on your radio, does the working one hear you? If you open your squelch, does it make noise?? If you transmit, does the RF power meter go up?? If any of these questions are YES, then there is a good possibility that your ANTENNA SWITCHING diodes are shorted or open. The TX diode is probably open and your RX diode is shorted. OR both. If the other radio is hearing you, and you are hearing the other radio, then the radio section is very likely OK. The diodes switching the antenna between RX and TX often fail, especially if there has been a lightning strike in the vicinity. It doesn't matter if your radio is on or not, or if you have a surge protector, a nearby lighting strike can take these diodes out.
If you don't have as much as a Channel number coming up on your radio, then the problem is most lkely somewhere in the radios internal power supply.
Jan 29, 2014 | Radio Communications
Loud squeal/feedback noise when transmitting from a Kenwood TK-3230 to a TK-3400U4p
If you're close enough to hear the receive on one radio while transmitting on the other, it's good old-fashioned feedback. Turn the volume down on the receiving radio.
Jul 11, 2013 | Radio Communications
What is a voic box on a cobra 29 ltd? What is a good antt combo four a 29 ltd?
Cobra's LTD 29 model Citizen's Band radio features the full 40 channels allowed and a heavy-duty microphone. The radio provides 4 watts of AM radio frequency output with a switchable automatic noise limiter and noise blanker. Other features include Cobra's Delta-Tune function. Making a Cobra LTD 29 hear and receive better involves making changes to the radio's settings, including the settings specific to this brand.
M/F Turn the switch labeled "NB/ANL, ANL, OFF" to the "ANL" position and try the transmission again if noise is affecting reception. "ANL" is an automatic noise limiter function and reduces noise caused by the vehicle's electrical systems and electronics.
M/F Switch to "NB/ANL" to activate the noise blanker, which may also reduce noise if you continue to have problems. It's an RF noise filtration function and will help with ignition noise.
M/F Adjust the "RF Gain" knob by turning it clockwise to increase gain in weak signal areas if you have problems hearing radio traffic.
M/F Set the "Delta-Tune" function to capture a more listenable signal and get rid of adjacent channel noise. Rotate the knob labeled "Deltatune" to the center position for best tuning. Try micro-adjustments to the left or right as well.
M/F Turn the volume up if you still can't hear and as with any CB radio, adjust the squelch if the radio is noisy when there's no traffic. Turn the knob labeled "Squelch" all the way to the left to receive all signals, including noise and turn the control clockwise until the background noise stops. You will be able to hear the strongest transmissions without having to listen to weak signals and noise.
The service manual can be found here
Jan 23, 2013 | Lands Phones
Cb transmit noise
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
I have a motorola t5720 and when I hit the mon key it makes no noise. I also do not have my manual. What do I do?
The monitor MON button may or may not emit noise. On some models of radios it will have "white noise" when pressed. On others it is silent. MON is used to be "polite" and see if anyone is talking before you transmit, assuming you have the interference code eliminator turned on. It temporarily shuts off your CODE. If your CODE is set to zero, you would never need the MON button, as you will hear all radio traffic anyway.
For simple operation of your radio, set all your radios identical to one another with the same frequency, code and Qt filter (if any). Use the Push-To-Talk (PTT) button to transmit, and release it when you are done talking to listen for a reply from a fellow radio user.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Oct 31, 2009 | Motorola Talkabout T5720 (7 Channels)...
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
29NW LTD CLassic No transmit flaky recieve
If you have a PRO510 try that mic on the Cobra radio see what you get.
Jul 16, 2009 | Cobra 29 LTD CB Radio
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
Recieving problems
turn the RF gain all the way up and leave it there. Also turn the squelch down until you hear white noise, then turn it up just until it goes away.
RF gain is how sensitive your receive is. The higher it is, the more range you have. There really is no need to turn it down ever, unless you are trying to not hear some one out in the distance. Normal operation, RF gain should be all the way up.
Now squelch is used to quiet non signal noise. Like white noise or interference noise, Or other radios with a really weak signal that you can't hear completely any way.
You just want it so it just quiets the fuzz noise. Depending on background interference and the amount of radio traffic, the may have to be adjusted to silence the noise you don't want to hear. When a strong audio signal is received, it will break the squelch, the higher the squelch is set, the stronger the signal needs to be to break it, otherwise it will silence it.
May 03, 2008 | Cobra 19 DX IV CB Radio
Radio Communications Logo
32 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
