Question about Brother Mfc-5840cn
Need to find my station ID to clear faxes
Need to clear Faxes not got station ID what is it how do I put this on
    Champion:
  • Brother Expert
  • 265 Answers
Faxes in memory ?
Posted on Jul 11, 2014
boyrevel
  • 71 Answers
SOURCE: Sending Faxes
This could be a cable fault. Get BT to do a line test for you (this is free). If that is OK, change the telephone cable. Perhaps this is on an extention cable? Remove it.
Posted on Aug 21, 2007
Faxman74
  • 5 Answers
SOURCE: receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Posted on Sep 09, 2007
Guru Guy
  • 95 Answers
SOURCE: 4100 RECEIVES FAXES, BUT WILL NOT SEND
does it give an error code?
Posted on Nov 26, 2007
SOURCE: Need to clear the memory of Brother MFC-8220 fax
Menu 2, 5, 1
Set fwd/page/store to *OFF
It will then ask if you want to delete all faxes in memory. Say yes.
Posted on Apr 29, 2008
greg_margo
  • 1959 Answers
SOURCE: Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
Posted on May 20, 2009
How do I change the fax number that is printed on faxes I send out
From the main menu select 0 for Initial Setup and then 3 for Station ID.
If you need a manual, you may download a copy here.
Mar 09, 2012 | Brother Multi-Function Center MFC-240C...
My fax machine is recognizing my home number which is line 1 in our house. I need it to recognize line 2
No fax machine holds your address. You can enter your fax number which is called the csi (caller station ID) and your Name (ie company name) called your TSi (transmitting station ID). thats all. Some machines will let you have multiple TSI's for different departments. I have never in 25 years on working on faxes ever heard of one holding an address!. The maximum amount of digits you can enter ranges from 15 to 30depended on make and model.
Srri
May 15, 2011 | Canon Office Equipment & Supplies
We have taken delivery of a fax from within our business but need to change the header/business name that recipients see when receiving faxes from us
Press the Menu/set key, then down arrow untill initial setup, then press, menu/set, then down arrow to station ID, then menu/set. From here you can change the info you need to change.
May 08, 2010 | Brother IntelliFax-2820 Laser Fax
Need to program to date stamp incoming emails
Hi Deanna, unfortunately it is not possible on this unit to have the date and time stamped as that is produced by the senders machine, this feature is referred to as the station ID on your brother machine.
Mar 26, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon printer 5440 "unable to print see troubleshooting routine maintenance manual" - message in led window
Open the scanner cover and remove any
foreign obstacles from inside the MFC. If the
error message continues, please follow the
steps below before disconnecting the MFC so
you will not lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all
faxes), and then reconnect it.
Check whether the MFC has faxes in the
memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
OR
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
OR
You can forward the faxes to your PC. Please
see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1.
You can move the faxes from your MFC’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and
then press Menu/Set.
The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
OR
To keep all faxes in the MFC’s memory,
press 2.
4. After the faxes are transferred, disconnect
(For details see Using Brother PC-FAX
software
on page 5-1 in Software User’s
Guide on the CD-ROM.)
These steps is on user manual.
Jan 16, 2010 | Brother MFC-5440 Printer
I want to clear spam faxes from brother 770
if you just want to clear out the faxes that are in the memory you would need to unplug it for about an hour then re-plug it. this will remove all faxes stored in the memory
Nov 11, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
memory
1.Press Menu/Set, 9, 0, 1.
and then reconnect it then do as above.
—OR—
another fax machine
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Change setting to not receive faxes at this station
Function 64 set
look for manual mode on the print out
set to manual through sim Function 74 set
Aug 11, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
When setting my brther fax machine it ask me for station ID and fax number
Station ID would be your name, business name, etc. And then enter your fax number, This info will be printed on all faxes you send. I don't believe you HAVE to enter either of these. MM85
Jul 27, 2008 | Brother Lands Phones
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother Mfc-5840cn Logo
48 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
