Question about Homelite Mighty Lite Lawn Trimmer
Homelite st-175g trimmer
Need to install string in my homelite. no manual. can anyone help?
  • 1,041 Answers
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
  • Jim Parker
    Jim Parker Jun 23, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
What is the spark plug gap for a ST-175G
Hi, .8 mm or 30 thou. Regards Phil.
May 16, 2011 | Homelite Garden
I have a homelite ST-175G string trimmer. How far out do you turn the two carb adjustment screws so it will start?
I would like you to look at this carburetor tuning tutorial by a major carburetor manufacturer. They answer all your questions here:
http://www.zamacarb.com/tipspage.html
May 01, 2011 | Homelite Garden
Does a homelite st-175g have a clutch?
I couldn't find a parts breakdown for your exact model, but on the ST-185, the clutch is optional. If you can remove the handle from the front engine cover (probably 4 Torx screws) and look inside, there would be a round 4" or so metal drum with the clutch inside right near the front of the cover. It is not hard to spot. Post back if needed.
Nov 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Gas leaking from damaged plastic bulb on primer. How ccan I replace it? Homelite Trimmer ST 175G.
If its built into the carb, 2 screws and a cover plate hold it in place. If it is externally mounted, if you look at it closely, you will see it may be snapped into place in the cover its in. Small engine shops and Ebay have the replacements.
Jul 31, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,597 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
