Question about Soltek Computers & Internet
Sl-85erv4-rl beep codes
When starting pc I hear several long beeps,and pc dont start,when removing the 4 pin power cable from PW1 slot then beeps stops but no boot
  • etrc_new Apr 13, 2014
    Hi Hwarang Fist, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? How many beeps do you get ? There may be a number of them, repeated over and over, the pattern that is repeated is the important thing. 13.April.204
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
The processor might be unsupported or damaged
Posted on Apr 24, 2014
SOURCE: Medion Motherboard
I had this problem with my Medion... what model is yours? The beeping is a code and indicates what the problem is. I called Medion support ant they asked me how many beeps and all that... they determined that the motherboard was toast and replaced it under warranty.
Posted on Nov 04, 2007
campus
  • 56 Answers
SOURCE: Two long beeps and no booting. Motherboard Soltek SL-75FRN2-L
You could try re-seating your ram and your video card if applicable.
2 beeps generally upon post depending on the bios is video or unstable ram.
Depending on how many sticks you have on the board try re-seating them if that doesn't work diagnose the faulty stick by putting them in 1 at a time.
Hope this helps
Posted on Jan 19, 2008
  • 101 Answers
SOURCE: atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
Posted on May 06, 2008
SubliMation
  • 219 Answers
SOURCE: No Video (Intel D945gnt) from boot
I'm having the same problem with my ECS K7S5A ver 3.1. The problem is that that I reset my FSB to an unsupported frequency using a 3rd party BIOS.
Unfortunately this is not the solution you're after, yet probably the only option. To fix the problem you're going to have to contact the manufacturer of the motherboard and let them know that you need a new BIOS ROM chip. You'll have to send the board to them and they will replace the chip for you. Depending on if you're still under warranty or not there may be a fee involved.
Sorry to see it happen to someone else, it is quite devastating.
Posted on Jan 30, 2009
Daholk
  • 41 Answers
SOURCE: My HP dv5000 laptop has AMI BIOS beep code - 4 beeps
It sounds like either RAM or VIDEO problem to me. (I can't remember the specific beep sequence for AMI bios errors).
Hard to diagnose in Laptops.... if it was a desktop you can just start swapping out the RAM DIMMS..... are you techo enough to check whether you have 1 or 2 RAM cards installed? If 2 then run it with each card in turn to see if it boots (indicating 1 faulty RAM stick). If only 1 then try running MEMTEST on it to see if any errors. (I like HIRENS if you have it... I think it usually has latest MEMTEST on it).
If your cards all pass then its very likely a video problem. If its onboard video with no expansion slot (likely in a laptop) then you may be buggered.
Let me know if you need a hand doing any of the above.
Posted on Mar 25, 2009
My ATI firepro V7800 makes continuous beeping noise. PC does not boot when I turn it on.....pls help!!!
1) Believe the continuous beeping you hear is a BIOS Beep Code, stating you have a graphics problem. Computer, not video card, is beeping.
2) Do you have the external 6-pin PCI-Express power cable plugged into the graphics card, from the Power Supply?
3) IF, your Power Supply does not have a 6-pin PCI-Express power cable, are you using TWO 4-pin Peripheral power cables, connected to a 6-pin PCI-Express adapter power cable?
To wit;
6-pin PCI-Express power cable example, and also showing a 6-pin PCI-Express adapter power cable on the right,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
Example of a 4-pin Peripheral power cable,
(Misnomered by many as a 'Molex' power cable. Molex was the first company to make that type of connector. The name stuck, kind of like calling an adjustable open-end wrench a Crescent wrench),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the color code of the wires used in a 4-pin Peripheral power cable, and a 6-pin PCI-Express power cable.
Red = 5 Volt wire
Yellow = 12 Volt wire
(All are DC Voltage)
Black = Ground wire. (ALL Black wires are Ground wires)
The 4-pin Peripheral power cable has ONE Yellow 12 Volt wire.
The 6-pin PCI-Express power cable has TWO Yellow 12 Volt wires.
The most power that a PCI-Express x16 expansion slot can deliver, is 75 Watts.
"This cable is used to provide extra 12 volt power to PCI Express expansion cards. PCI Express motherboard slots can provide a maximum of 75 watts."
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
"The older 6 pin version officially provides a maximum of 75 watts (although unofficially it can usually provide much more)"
The ATI FirePro V7800 graphics card requires 150 Watts by itself.
The PCI-Express x16 expansion slot CANNOT deliver the recommended power (Wattage) needed, therefore an external power cable capable of delivering 75 Watts is needed.
What happens if you just use ONE 4-pin Peripheral power cable, in a 6-pin PCI-Express adapter power cable?
The PCI-Express x16 expansion slot contact pins -> BURN
The gold plated contact pins on the bottom of the graphics card -
BURN
The connection on the graphics card for the 6-pin PCI-Express power cable - BURNS
The contact pins in the 6-pin PCI-Express adapter power cable -
BURN
If it is too bad, and cannot be remedied by cleaning, the motherboard is TOAST, and so is the graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 30, 2012 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I get beeping when I start the computer, and it wont start?
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Oct 18, 2010 | Dell Dimension 3000 PC Desktop
No display
first check wether ur monitor light is blinking if not there is problem with ur display or the power is not correct if all this is ok and ur monitor light is blinking remove the cpu cover remove the memory and restart ur computer in new motherboards muzzers are fitted on the motherboard or else connect a buzzer to the speaker pin iin the frontpannel and restart the computer with no memory you will hear 2 long beeps it means the memory is not present then clean the memory pins eith an erasor dont use any metalto clean the memory insert the memory in the nemory slot if you hear again the long 2 beeps it means the memory is fried if you hear one beep means the memory is fine and the system is working still no display means then check if the display card is addon or motherboard built in if addon change the addon card if built in contact chiplevel service person also check the ponit cable connected firmly to the computer with 2 screws on the cable tightened to the cpu
Oct 14, 2010 | Dell OptiPlex 360 Desktop Computer
Hello I have a T2682 and I have taken this computer apart many times and I just got back from Afghanistan and just wanted to see if I could get it going one last time but I forgot what wires plug in where...
The beep you hear is a BIOS Beep Code. The computer's method of informing you something is wrong, and the area to look into for it.
The code is similar to what you may be used to.
(Afghanistan, Army? If so, hello brother/sister. 1st Cav, 13th Sig. Corp)
The BIOS Beep Code is similar to a Morse Code.
Examples:
Two short beeps followed by a long beep, a pause of silence, then the pattern repeats, over, and over.
One short beep indicates everything is okay.
This is an indication that BIOS has concluded the Ram Memory count, and everything is 5 By.
According to my sources, the eMachines T2682 desktop computer uses an Imperial GV motherboard model, made by TriGem.
The front plastic cover of your computer is the Front Panel.
The area on the motherboard that the cables, (Wires), attach to on the motherboard, is the Front Panel header.
This is the Front panel header pinout, for the TriGem Imperial GV motherboard,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_support.shtml
On this page I would like you to scroll down to the heading -
Imperial GV Front Panel Motherboard Pinouts
Looking at the pinout;
1) Pin 1 is Not used. NC = No Connection
2) Pins 2 and 3 are for the Power On LED light
[Light Emitting Diode]
Pin 2 is for the Ground wire. (GND) ( - )
Pin 3 is for the LED light power wire. ( + )
3) Pin 4 is not used. NC
4) Pins 5 and 6 are for the Harddrive Activity light. (LED)
HDD is HarDDrive
Pin 5 is for the LED power wire
Pin 6 is for the HarDDrive signal wire
(If after attaching the wires the HDD LED light is dim, reverse the wires)
5) Pins 7 and 8 are for the Power On switch.
Pin 7 is for the Ground wire.
Attaching the Peripheral cables;
1) You have an IDE harddrive. Uses a 40-pin IDE ribbon cable.
(39 actually. One pinhole is blocked off)
There is a Locating Tab on one side of the IDE ribbon cable's connector.
To wit:
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
Left-click on the blue IDE connector in the photo to the upper right.
At the top middle of the connector you will see two ridges.
This is the Locating Lug.
Now left-click on the IDE connector on the motherboard, shown in the photo to the upper right.
(To the right of the blue IDE connector)
Looking at the blue IDE connector on the motherboard, you will note there is a cutout on one side of the connector.
This is a Locating Slot.
Lining the Locating Lug up to the Locating Slot, puts the pins of the IDE ribbon cable's connector, in the correct position for the pinholes in the motherboard's IDE connector.
IF, your ribbon cable's connector does Not have a Locating Lug;
Look at the outside edge of the ribbon cable. You should see a faint Red stripe.
The Red stripe is always next to Pin 1.
Next to the motherboard's IDE connector should be a printout.
It will state PRI 1, (Stands for Primary 1), or IDE 1.
This is for the Harddrive.
[ If you see PRI 2, or SEC, (Secondary), this is for the optical drive.
(CD/DVD drive). Using this information, you will know the other IDE connector on the motherboard is for the Harddrive ]
That printout is always next to where Pin 1 is.
Therefore on the motherboard, the side of the IDE ribbon cable that has a Red stripe, will go next to the printout.
If your harddrive does not have a Locating Slot on it's IDE connector, Pin 1 is always towards the 4-pin IDE power pins.
To wit:
The above is a webpage from Playtool.com, discussing the various power cables used in a PC, and more specifically the standard 4-pin Peripheral power cable.
I linked it to show you a standard 4-pin Peripheral power cable, plugged into an IDE harddrive.
(A Peripheral power cable's connector, has been misnomered as a Molex connector, repeatedly through the years.
This was the name given to the first connector of this design.
It's kind of like referring to an adjustable open-end wrench, as a Crescent wrench )
Here in the photo of the rear view of an IDE harddrive, (Photo to the far left), you will see the 4 power pins.
To the left of the power pins are the Jumper pins.
To the left of the jumper pins, is the IDE interface for the 40-pin IDE ribbon cable.
The Red stripe of the IDE ribbon cable goes towards those 4 power pins.
To be continued in an additional comment.
Sep 19, 2010 | E-Machines eMachines Desktop PC
5 beeps are coming and after some time five beeps are repeating.system not booting
Hi ,
When you hear 5 beeps while booting or turning the computer off it is related to the operation of critical motherboard components - such as the CPU.Please try these steps to try fixing this problem .
Open up the computer tower and then once the side panel is out a test on the motherboard needs to be done and to do that look for the memory cards(Ram ) which would be green in colour,4 inches long and would be inserted in a slot that has clips in either ends that holds the card in the slot firmly.There can be one or more than one so remove the memory cards and then turn the computer on by just connecting the power cable,you should hear long beeping noise if you dont hear any then the motherboard needs to be replaced or needs to be serviced.
allthe best
May 20, 2010 | HP Workstation xw4200 PC Desktop
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
Whenever i start my pc fan's start's even monitor start's imediately but 'no signle' massage appears on screen & monitor screen got off
Do you get any "Beep" sound coming from the internal speaker, if so is it just one straight beep or numerous beeps.
If it's one straight beep then this indicates the PC has passed it's POST (Power On Self Test), if it's a series of beeps, some long, some short, it means there is some problem inside the computer, like loose graphics card, RAM, CPU, cable, etc. The beep sequence should be in your motherboard manual under beep codes. That will give you a hint as to what to look for next.
If it is one straight beep and PC passes POST then check your monitor connections, and monitor, it could be that the power saving/signal detection pin is either not connected properly, or damaged.
If you don't have the internal speaker connected (normally in the bottom or front of the case), you need to connect this to find out what is going on.
If you need to connect it you should look at your motherboard manual for where to connect it, normally if you look at the motherboard you will see a load of thin cables coming from the front of the case going onto the motherboard at a point, the 4 pins on the bank of pins at the end are normally the PC speaker (you also get a blank pin between them and the Power Switch pin), although check your manual first, or see if you can see the SPK connection on the motherboard (normally Gigabyte boards are very well marked for this, and colour coded.)
Oct 31, 2009 | Computers & Internet
Atx12v1 cable
May 02, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Computers & Internet Logo
60 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
