Question about Garden
I have a homelite 12amp 20" corded electric mower
I have a homelite 12amp 20" corded electric mower that I used only 3 times! It stopped working in the middle of mowing& won't start again! Are there any fuses?
    Problem Solver:
  • 29 Answers
Can you give me the model number off the unit and I will be more than happy to get the breakdown on it for you and we will find out for sure? I would say from the things I see in my shop that there is an issue with the switch.. i will be more than happy to help you through this... Best of luck..
Posted on Apr 13, 2014
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Stuck brushes,in the brush holders caused by corrosion,unplug the cord first,remove the cover and look for two carbon brushes that should be contacting the motor,if not stuck they may need replacement !
Electric Mower zapped?
They should replace it. They broke it. If it was just a cut in the cable it should work again, but they have probably burnt it out. Change the fuse first also as that would have popped.
Jul 13, 2013 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
Triped cb
Make sure you are using an extension cord that can handle the amperage. If so then you've likely got an electrical short somewhere. Your extension cord should be at Least as large as the cord on the mower or larger.
Nov 20, 2011 | Garden
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
