Question about Akai Televison & Video
Voltage regulator unusual light blinking for 2 days ..yellow light
For the past two days my stablizer has not been onwhen its been powered the unusual light turns on and blinks ,it has been like that since 2 days now.. what might be the problem?
SOURCE: Green LIght Blinking
replace the DM or have someone repair the DM. The capacitors are bad and someone who knows how to repair circuit boards can replace them
Posted on Nov 06, 2007
  • 80 Answers
SOURCE: power was off
You need to replace 4 capacitors on the DM board. It is located inside a metal box on the left side of the set, looking from the rear. The original parts are 1000uf 16v. You will need to install 1000uf 25v or 35v. They are located at the top of the board and are green colored.
Posted on May 31, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
SOURCE: i have a mitsubishi 1080 series wt-42311 model
i have a mitsubishi 1080 series WS-65315 model i power it on and led light turns off after 2 seconds
Posted on Oct 18, 2009
UPS does not supply power under 150~ volts
UPS will provide constant voltage out put.
The average working condition of UPS is 170 to 270 volt.
Below the level may not work.
Jul 20, 2012 | Computers & Internet
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
I have a Dell precision 670 dual ZEON CPU ws and it has stopped working (Note after a move) diag lights ( on the front panel) A,B,C are lit and yellow, the power button is yellow instead of green and the...
Reseated? How Rick?
Did you;
1) Have the computer unplugged from power, and follow Anti-Static Precautions?
2) Did you clean the top of the processors, and bottom of the Heatsink's - Thoroughly, and properly apply new, fresh thermal paste?
[ If they had thermal pads on the Processors, remove them, throw them as far as you can.
One, they are JUNK. Two, you cannot reuse them.
The imprint has been made, and you cannot imprint over.
{The Heatsink, and Processor make an imprint on a thermal pad. The pad is squeezed down. You cannot re-squeeze again, and make a successful complete contact. A thermal pad also dries out a lot faster than thermal paste. Poor design ]
3) The LED lights you refer to are Diagnostic LED lights.
A, B, and C are Yellow.
The Power On LED light is Yellow,
Dell Support > Precision 470 and 670 Workstation Desktop PC Users Guide,
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/index.htm
Solving Problems
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/solve.htm#wp1252394
Power Problems:
If The Power Light is Amber and Green or Steady Amber;
A device might be malfunctioning or incorrectly installed.
  • Remove and then reinstall the memory modules.
  • Remove and then reinstall any cards.
  • Remove and then reinstall the graphics card, if applicable.
Diagnostic Lights before P.O.S.T. (Power On Self Test)
A, B, C, are Yellow, D is blank or Off.
BIOS is not executing - Ensure that the Processor is seated correctly, and restart the computer.
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1057482
Almost sounds like a problem with the motherboard voltage regulator circuit, if the Processors were handled with Anti-Static Precautions being observed, and new thermal paste being used, after proper cleaning.
{A Processor is the MOST susceptible computer hardware component to Static shock}
Motherboard Voltage Regulator Circuit
A series of Electrolytic Capacitors on the motherboard, (Yes, in a Series circuit, also), that among other duties, regulate voltage for the Processor/s.
http://www.hardwaresecrets.com/article/616
Computer unplugged from power, Anti-Static Precautions observed, remove the motherboard, and visually inspect all 'caps' on the motherboard,
http://www.capacitorlab.com/visible-failures/index.htm
Post back as to your findings, in a Comment. (Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell Precision Workstation 670 PC Desktop
No power, fast blinking flashing green light where I plug power cord in.
Good day
Kindly provide the following for us to provide a direct and final solution to your problem
1. Does the blinking light changes from yellow to green or vice versa? 2. Is there a blinking red light? 3. How many blinks do you think it blinks?
Should you have any questions regarding the questions above, feel free to approach and ask us.
Good day and God Speed.
Jun 14, 2010 | Computers & Internet
I have a Sony kv-40xbr800. The standby light flashes 6-7 times and does not turn on. If left off for a couple of day, it may turn on. Is there an easy fix?
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Jun 05, 2010 | Televison & Video
The TV (Dynex DX-LCD32) will not come on. The
I have a DX LVD33 power light is red and no picture or sound screen is black. Please advise.
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Two years ago my Voltage Regulator went bad and over-charged my new battery to the point that it swelled up. The Yamaha dealership replaced both the battery and Voltage Regulator. Two years, almost to the...
If you're going through regulators that often I would suggest going after the stator. Make sure it's not grounding out on the chassis. Find the 3 yellow or white wires that are connected to the regulator. using a meter in OHMS ( looks like the horseshoe ) with the bike off check wire one (red ) to wire 2 ( black ) then wire one ( red ) to 3 (black ), then 2 (red ) to 1 ( black ) and 2 ( red ) to 3 ( black ) , then pick one ( red ) and black to the chassis, motor, ground. somewhere metal on the bike. The first series of tests you should get some sort of numbers, ( which should be somewhat close in numbers ) When you go to ground, Chassis you should get no numbers, OFL, OL, or the horseshoe sign if you get numbers there, the stator is bad and your transmitting ac voltage to the chassis.
Aug 27, 2009 | 2000 Yamaha V Star 1100 Classic
My ps3 won't let me insert any discs into it, the ps3 turns on, then light goes yellow and within a second or so the dam thing has turned off and the light is flashing?
The Problem is the Voltage You Would Have to Buy a Stablizer For it which is matching the power for the ps3 i was having the same problem with my xbox Thank You
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Want hold a charge
get a test light and a schematic. unplug stator plug.start bike ,make sure battery has full charge. test each pin on connector that is attatched to the 3 yellow wires.should light on each pin. if all good check for burn marks around connectors, front & back sides, and on wires. if no power on yellow wires, stator problem. if power, plug connector together, now test for voltage in wires on the voltage regulator side of the connector, to see if the voltage is making it through the connector.if there is power to volt. regulator,test w/ multi meter across battery leads to see if there is charging voltage to battery,approximately 13-15 volts. if only battery voltage(12.2 or less) while bike is running,voltage regulator is no good.if charging good, but bike wont start after prolonged sitting(say overnight) a system amp draw test is needed to see if something is staying powered up while bike is not running, drawing down battery.
Feb 18, 2009 | 1994 Suzuki RF 900 R
Televison & Video Logo
89 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
