Question about Lenovo G550-29583AU Notebook
Lenovo g550 notebook 2958 keyboard typing numbers instead of letters in search bar
When i try to type in the search bar only numbers display.. no letters
techservant
  • 10 Answers
SOURCE: problem with keyboard
When you hook an external keyboard to it, does it type normally? I am guessing it probably does but you need to test that first. Find a USB keyboard, hook it to it, wait for it to start working and check it out.
If the external keyboard types normally as I think it will then you probably need a new keyboard. If however your computer was damaged by moisture or unnatural compression to the keyboard, a new keyboard may not fix it. Moisture damage or compression damage to the computer can be permanent, but my first guess is a keyboard would do the trick.
Taking the keyboard off a Lenovo (less than 4 years old) is very easy. There about 4 or 5 screws on the bottom that need removed and the wrist rest (which pops out) then they keyboard comes out pretty easy.
Posted on Jul 31, 2009
eagle338
  • 4889 Answers
SOURCE: Lenovo G550 (2958-ACU) the display is scrambled/folded
Your computer uses Onboard graphics(Intel Graphics Media Accelerator (GMA) 4500MHD) which means the GPU is embedded into the motherboard. The problem is most likely to be the GPU as you have predicted. If your laptop is under warranty you should push for a replacement as opening it will void your warranty. However if its out of warranty then you will need to remove the keyboard to access it. Check for bad connectors from the video card. Unplug the connectors wipe them with a cloth and then plug them back in. Power up and see if it resolves the issue.
NOTE: TO AVOID DAMAGING THE BOARD COMPONENTS WITH ESD AN ESD WRIST STRAP IS MANDATORY FOR THIS FIX .
Hope this helps,
Sai.
Posted on Jan 25, 2010
etaf
  • 779 Answers
SOURCE: keys are not working correctly on key pad
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
Posted on Apr 13, 2010
SOURCE: My laptop Lenovo G550 2958
i need all drivers
Posted on Dec 14, 2010
SOURCE: checksum validation failed for the PIN entered on Lenovo password for internet set up
OK, if you have a Password, why are you entering a PIN? They are two different ways of authenticating you as a valid user. You should not select the option to use a PIN. Use your Password or Network Key.
Posted on May 14, 2012
How do I type accents on a laptop without a secondary numeric keypad?
Type character map in your windows search box and select the font you require. You may need to download the windows language pack for each language you use.
Oct 26, 2014 | Compaq Computers & Internet
How do I get the keyboard to type in youtube search engine (browser) on my Lg smart tv?
As of right now youtube doesn't recognize USB keyboards. They are coming out with update to fix it.
Jul 24, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
What is the difference between Porter-Cable air compressor models that have a type 1 or type 2 behind the model#?
When searching for a tool or machine part at eReplacementParts.com, the product's model number and type number are always necessary to ensure an accurate part match. Even when a model or type number is only different by one digit, the parts for that model or type may not be compatible with other models and types.
Each manufacturer uses a different model and type number system, and manufacturers often call type numbers by different names. Some type numbers are especially difficult to find on the tool or machine.
This article provides explanations and pictures for finding model numbers and type numbers for several tool and machine brands, making it easier to order the right part for the right tool.
Explanations are listed below alphabetically by brand, but first, some additional information about model numbers and type numbers will be helpful.
Model and Type Numbers
Model numbers distinguish a manufacturer's models for a certain kind of tool within a given tool category (like drill/drivers and nailers). For example, two different power sander designs from the same brand would be distinguished by having two different model numbers. This is true for every b rand, that they separate major designs by model number.
However, manufacturers often update the design or features of a tool model, creating types of tools with the same model numbers. Most manufacturers distinguish the different types of a tool model from one another by assigning type numbers to them in addition to the tool's model number.
This is where it gets tricky. Finding type numbers for tools can be difficult because of the following reasons:
  • Type numbers can be very different from brand to brand. Sometimes an entire type number is just one digit or letter, and sometimes type numbers are very long numbers or long combinations of letters and numbers.
  • "Type numbers" go by different names, depending on the manufacturer. Some manufacturers call them type numbers, while sometimes they are called the: engineering number, series number, or bar code number.
  • Some model types are only distinguished by the year of the model.
  • Type numbers can be very difficult to find, sometimes located on the inside of a tool's housing (like some Ryobi tools). Fortunately, most type numbers are listed on the name plate with the model number.
  • When a manufacturer does not anticipate redesigning a tool or machine model, the first type of that model often does not have a type number assigned to it by the manufacturer. Designs that follow the first type will usually have type number designations.
  • Some manufacturers do not use a type number system at all, and instead change model numbers for each new design. In this case, the model number is the only number needed to match the right parts to the tool or machine.
In general, when searching eReplacementParts.com for the right model number and type number of a tool, the most important idea is just to match all numbers displayed on the webpage (under that tool's picture and name) with the numbers on the product.
On eReplacementParts.com, type numbers are displayed under the tool picture to the right of the model number. Sometimes type numbers are displayed in parentheses, like "(Type 1)" or "(0601916460)". Models that are not assigned type numbers will not have a type number displayed on the web page.
However, we will often list "Type 1" or "Type 0" for the first redesign of a tool model in a type series, even if the manufacturer does not list "Type 1" or "Type 0" on the name plate. This makes it easier for our customers and us to tell the first type apart from the rest.
Jan 19, 2010 | Porter Cable Air Tools & Compressors
Need to find wireless mac address for asus Eee pc 900a. Can't join wireless network till I find it.
If you are using windows, click the start button, in XP click run (vista just type in the search bar), type in "cmd", once the command window is up, type in "ipconfig /all"
look for the wireless card and the mac address will be the one with the ":" separating the number/letters
Aug 05, 2009 | ASUS Eee PC 900 PC Notebook
Cursor errors when typing in yahoo search bar
open yahoo thro.othet other engines like bing
Jun 30, 2009 | Dell Dimension E510 PC Desktop
When I try to type numbers...letters pop up.
press alt or arrow key and select the number key .........repeat the same when u want the number to get displayed in place of letters
Jun 28, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
I am unable to install my HP PSC 1500 Printer do not have the drivers
Here's a link to drivers for the 15_10_, which may work or at least get you in the ballpark. There's a search box in which you can try in vain to search for the 1500.
On the back of your printer, there should be a sticker with a bar code on it. Above the bar code should be a series of numbers and letters starting with Q. That's your actual model number, regardless of what the printer says; type that into the search box (including the Q)
Here's the link to get you started:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=psc+1500&submit=Go+%BB
Dec 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Dialing on 755p
Ok theres two ways to do this, heres 1 way: press menu while you our on the phone display (the button to the right of alt) use the 5 way navigator to move to the right, scroll down to phone display options. Below the Show Dial Pad/ Show Wallpaper, you'll see where it says typing dials phone number change that to typing starts contact search. This will permanently make it liek your old treo. If you wanna dial numbers press the white button to thte left of z and start dialing the numbers.
Version 2: If you dial normally it will dial numbers, if you press th white button to the left of z then type contact name also works.
hopes this help
Masalama
Feb 08, 2008 | Palm Treo 755p Smartphone
Mean (x-bar), variance (s^2) and standard deviation (s)
Enter 1 then press the (SIGMA)+ button (SIGMA) looks like a sideways capital M ....its a Greek letter.
Then enter 2 and press the (SIGMA)+ button
Then enter the next value and press the (SIGMA)+ button
After you press the (SIGMA)+ button the calculator displays the number of numbers you have entered
Once all numbers of your sample have been entered press 2nd and the button corresponding to x-bar
sample st. dev is the (sigma)n-1 button (need to use 2nd button)
variance is (std. dev.)^2
population st. dev is the (sigma)n-1 button (need to use 2nd button)
Jan 18, 2008 | Texas Instruments TI-30XA Calculator
Lenovo G550-29583AU Notebook Logo
46 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
