Question about Amcor PLM-14000E Portable Air Conditioner
Model arp-815 prtable roam air conditiones - Amcor PLM-14000E Portable Air Conditioner
Window kit for RS ARP-9411
I assume you are looking for the window kit for ARP-9411 Portable Air Conditioner. If so, contact
Royal Sovereign Customer Support 1-800-397-1025 .
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Royal Sovereign ARP-1000EX Portable Air...
Unable to locate a printable manual for the 1008.
Max, the following link is to your Owner's Manual. You may download and print it for future reference.
http://www.air-conditioner-home.com/manuals/ARP-1008Manual.pdf
I hope this helped you.Please let me know.
Jun 30, 2011 | Royal Sovereign ARP-1008 Portable Air...
Model arp-900e wont start keeps popping breaker
Sounds like you have a short or a groud in a fan motor or compressor motor. You can unhook one component at a time and turn it on after each component is disconnected to figure out which one is grounded.
May 03, 2010 | Royal Sovereign Portable Air Conditioner
A red light came on and the unit turned off
see if you can push water from the other end to see if you have something that stuck inside
Sep 08, 2009 | Royal Sovereign ARP-1008 Portable Air...
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
How many watts does an ARP-3012 draw?
Assuming you are in the United States....
This unit should work fine on a 15 amp circuit assuming there aren't several other loads on the same circuit.
You didn't say what the BTU was for you unit, but there are about 3.41 BTU's per watt. Multiply the btu rating of your unit by 3.41 and then divide by 115 or 120 (your house voltage in the U.S., use 220 for Europe) and that number is the amps.
Apr 07, 2009 | Royal Sovereign ARP-3012 Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
185 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
