Question about Yamaha RX-V575 3D A/V Receiver - 7.2 Channel - Black
Yamaha rx-v675 hdmi board defective
Where can I get a replacement hdmi board?
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
Benimur
  • 6966 Answers
SOURCE: Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
Intermittent sound Yamaha RX-V675 amplifier.
Loose wire, maybe power or remote on. Some vehicles have their own amp, which could have a problem. Could be a bad ground. Check wiring and connections.
Apr 15, 2017 | Cars & Trucks
My Yamaha rx-v675 started flashing decoder off goes from dolbydig to decoder off and sound cuts out few secs then back on occasionally goes to static just started few day ago dish conn w hdmi cable
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Feb 15, 2017 | Yamaha Televison & Video
How do i set the impedance ?
Check the page 105 english manual at http://download.yamaha.com/api/asset/file/?language=en&site=europe.yamaha.com&asset_id=58929
You can change the speaker impedance in advanced menu. With receiver in standby, press the MAIN ZONE button on front panel while holding down the STRAIGHT button. You should now see ADVANCED SETUP on the display. Use "PROGRAM < >" buttons to navigate to "SP IMP." screen. Then use STRAIGHT button to change the impedance. Finish by turning the receiver off by pressing MAIN ZONE button.
Sep 27, 2014 | Yamaha RX-V675
Yamaha rx-v663 no video from hdmi out
Unfortunately the most common cause of this is the HDMI transmit IC on the digital board. Sometimes replacing this IC will work, but most of the time you will need to replace the digital board - this is expensive. If you don't have a warranty that is still valid, it may cost more than a new receiver.
Dec 23, 2012 | Yamaha Audio Players & Recorders
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
What kind of up-grades are for the yamaha
There are no "upgrades" however, if your having problems with HDMI switching or "not working" You can send it to Yamaha and they will replace the HDMI board at n/c. It's still version 1.2 and the current version is 1.3a soon to be 1.4. What is it that you need to have upgraded? Post a comment with what it is you would like your receiver to do and I can help you further. I work with Yamaha daily
Nov 25, 2009 | Yamaha RX-V2700 Receiver
HDMI out jack physically broken on my rx-v1900. Fixable?
An audio repair shop should be able to get a replacement connector and swap it for you. I doubt that the part is available from Yamaha (and it would be pricy if it was). The connector shouldbe available generically. Digikey or Mouser should be a good source.
Dan
Nov 18, 2009 | Yamaha RX-V1900 Receiver
Yamaha RX-V575 3D A/V Receiver - 7.2 Channel - Black Logo
161 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
